have you also configured the license service. Installing the license manager software only is not sufficient.
1. Click Start > All Programs > Autodesk > Network License Manager > LMTOOLS
Utility.
2. In the LMTOOLS utility, on the Service/License File tab, make sure the Configure Using
Services option is active.
3. Click the Config Services tab.
4. In the Service Name list, select the service name you want to use to manage licenses.
By default, the service name is Flexlm Service 1. If FLEXnet® is managing other software on
your computer in addition to Autodesk®, you can change the service name to avoid confusion.
For example, you can rename Flexlm Service 1 to Autodesk Server1.
Note: If you have more than one software vendor using FLEXnet for license management,
the Service Name list contains more than one option. Make sure that only one Autodesk
service is listed.
5. In the Path to Lmgrd.exe File field, enter the path to the Network License Manager daemon
(lmgrd.exe), or click Browse to locate the file.
By default, this daemon is installed in the C:\Program Files\Autodesk Network License Manager folder.
6. In the Path to the License File box, locate or enter the path.
This is the path to the license file obtained through autodesk.com or the location where you
placed the license file if you obtained it offline.
7. In the Path to the Debug Log File box, enter a path to create a debug log, or click Browse to
locate an existing log file.
It is recommended that you save to the C:\Program Files\Autodesk Network License Manager
folder. The log file must have a .log file extension. For new log files, you must enter the
.log extension manually.
8. To run lmgrd.exe as a service, select Use Services.
9. To start lmgrd.exe automatically when the system starts, select Start Server at Power Up.
10. Click Save Service to save the new configuration under the service name you selected in step 4.
Click Yes when prompted if you would like to save the settings to the service.
11. Click the Start/Stop/Reread tab and do one of the following:
- l If a service has not yet been defined for Autodesk, click Start Server to start the license server.
- l If a service for Autodesk is already defined and running, click ReRead License File
to refresh the Network License Manager with any changes made to the license file or
options file.
The license server starts running and is ready to respond to client requests.
12. Close LMTOOLS.
Marco Müller
Product Support Specialist
Digital Simulation
