VRED VR Clipping Plane Tool / Module Help
bpuent
bpuent
I'm currently running VRED 2023 Pro and I am trying to figure out how to add the VR Clipping Plane Tool.  I've seen some posts on the forum where in their Script drop down menu they show a VRClippingModule listed.  I have no such option.  Can anyone tell me how to activate it or tell me how to install it?
Thank you,
-BP
TillmannDorsch
Hi @bpuent
This video tutorial explains well how to customize the VR menu and add your own Python scripts:
https://help.autodesk.com/view/VREDPRODUCTS/2023/ENU/?guid=VRED_Tutorials_Python_Tutorials_11Tutoria...
In your case the Python script might look like this:
# Function to initialize and active the Clipping Module
def clippingEnabled():
print("Enable Clipping")
Clipping = enableClippingPlane(true)
# Function to disable the Clipping Module
def clippingDisabled():
print("Disable Clipping")
Clipping = enableClippingPlane(false)
# Create the tool, set its name and connect to the on and off state
VRClippingPlane = vrImmersiveUiService.createTool("Clipping")
VRClippingPlane.setText("Clipping")
VRClippingPlane.setCheckable(True)
VRClippingPlane.signal().checked.connect(clippingEnabled)
VRClippingPlane.signal().unchecked.connect(clippingDisabled)
Tillmann Dorsch
Product Owner for Visualization
TillmannDorsch
Ihor_Skoda_Design
I've created a custom clipping plane (vrdClipPlaneNode) according to example "clipPlane.py". I wonder if is there a possibility to control its color via Python like it is done in vrClippingModule (Interaction > Clipping > Visualisation)?
Thanks in advance.
Ihor_Skoda_Design
Thanks in advance.
Christian_Garimberti
Hi, a vrdClipPlaneNode is not the same of the clipping module.
It has no parameters, just a plane to cut the visibility of child nodes.
To use and manage the Clipping tool you have to use the vrClippingModule (Api V1)
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
