VRED Reset to default interactions
LeviathanLevi
LeviathanLevi
I was messing with custom interactions and at some point deleted/removed the defaults running the code below. How do I reset it all back to the defaults? I don't see any option to just restore all of the default interactions/actions groups to the connected devices.
print(vrDeviceService.getActiveInteractionGroup())
print("Changing active interaction group")
resetInteraction = vrDeviceService.createInteraction("resetInteraction")
resetInteraction.setSupportedInteractionGroups(["resetGroup"])
vrDeviceService.setActiveInteractionGroup("resetGroup")
for interaction in vrDeviceService.getInteractions():
    print("deactivating interaction: " + interaction.getName())
    vrDeviceService.deactivateInteraction(interaction.getName())
    #Remove any actions
    for action in interaction.getControllerActions():
        print(action.getName())
        interaction.removeControllerAction(action)
        print("removed.")
    #Remove any action groups
    for actionGroup in interaction.getSupportedInteractionGroups():
        interaction.removeSupportedInteractionGroup(actionGroup)
    #Remove interaction
    vrDeviceService.removeInteraction(interaction)
What's the easiest way to reset my controllers to their default interactions after deleting them?
Thanks!
quirin.friedl
Did you manage to handle the default/custom interactions at some point? I'm also getting into this and I think I have simular problems. When I create a CustomInteraction and a CustomGroup like in the examples, the default interactions don't work any more, even so this is supposed to prevent this (I guess...).
When I assign all existing Interactions to the same group, everything seems to work, but the VR Menu is broken. Any one who can explain this a bit better because the behaviour is not very self explaining?!
