hi all, new here.
i cant reach the edit matiral dialog box , how can i load it
all i have is a "MODIFY" BUTTON where i can change just a few things.
hi all, new here.
Solved by dlincol1. Go to Solution.
If I understand correctly, just disable the Simple UI button in the top menu to see more options.
thank you, told you im new here 🙂
