VRED background color
I started to use VRED for a car rendering and I want to change the background color as a 'white' one(like a Keyshot default background).
But, even I put some white material on a background and render it, all of stuffs are quite dark..
I've tried lots of times to change it to a white, I cannot find right one.
I also watched some videos related to Vred by Youtube and basically the background color is white at those videos.
I want to change it like that..
Please help me.
Edit >Preferences > Render Options > Visualization Advanced > Background, click on each set of numbers and Choose Color (white for both), Apply.
Make sure you turn off Is Visible for your Environment Material.
You can also play with Background Color in Render Settings.  I forget how that works exactly- has something to do with OpenGL vs. RT renders.
I got it. Thank you so much~:-)
Jonny.Murty
Can you elaborate on this please? I cant find it and i'm guessing thats why my background colour choice doesnt work.
marcus_fritzen
In the Material Editor (Scene - Material Editor), select your environment material(s) e.g. Studio and uncheck "Is Visible" in the Environment Material frame.
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
Thanks for the information.
