VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Translation on X with a Y Orientation
12 REPLIES 12
Message 1 of 13
nharis7
819 Views, 12 Replies
I am trying to translate an object on X. And I gave -23 to its y-orientation but it does not move the way it should.
I am also attaching a link for the video and you can see there y-orientation and the object should move in a tilted way not in a straight line. Or maybe I am missing something.
Best Regards
Harris
Labels (3)
12 REPLIES 12
Message 2 of 13
Hi,  there are no link or attached video...
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 3 of 13
Message 4 of 13
Hi, if i have understood you moved the box using the X manipulator and you would like to see it moving along the "Rotation" manipulator you set active?
This is not possible.
The Rotation manipulator act only for Rotation around Axes, not for Translation
if you want to "rotate" the translation you have to put your box inside another Node and rotate this (and obviously rotate the box of the same value in the opposite direction)
Then, Moving the Box, it will follow the Parent Node orientation.
Best
Chris
Message 5 of 13
Thanks for you reply ... still the box does not work the way I want. So, I just found a formula to do that with the script and it is working not perfectly but fine.
Greetings
Haris
Message 6 of 13
Maybe i didn't understood what you mean...
Could yo share the solution so other people can benefit of it?
Best
Chris
Message 7 of 13
Hi Chris,
Please have a look at my attached link and sorry for the dots and planes in the video as my graphics card get roasted.
https://drive.google.com/file/d/1SCHqDRaHr7zjqlMKIAfgSapIRdjtzmLf/view?usp=sharing
In the link, I showed you what a want to achieve in Vred but I think it is not possible in Vred. But if you know how to do this then please let me know.
The solution I adopted is, I used a formula to move the object in x and z both at a same time. And I cannot share the code here because I work for a company. Hope you understand.
Greetings
Haris
Message 8 of 13
Hi, you can do what you show in the video by activating the "Local Mode" in the Transform button.
Best
Chris
Message 9 of 13
But when you try to move it by entering values in x. It doesn't move the way I want. You can give it a try and I also tried it moving with local translation code but still move in a straight line.
Greetings
Haris
Message 10 of 13
Ok, lets try adding the 2 advice...
  1. Create a group, add the box inside it. rotate the group, and not the box (so you see the box rotated)
  2. Using the x coordinate (while the box is selected) results in a translation along the x axis of the box, so physically along the rotated group axis.
Activate the local mode you will see the rotated manipulator. This is useful only if you want to graphically manipulate the box.
Is this combination right for your needs?
Best
Chris
Message 11 of 13
I tried your method you answered before but it didn't work. I will also try to make a video on that and share the video with you.
But I will not be able to do so before Monday. As, I am not in the Office.
Greetings
Haris
Message 12 of 13
is this https://youtu.be/4ywms75LdLg what you want to do?
Message 13 of 13
That's great. I was moving the group and it was not working the way I wanted. Now I know, that I have to move box in the group.
Thanks for making a video.
Greetings
Haris
