Htc Vive Object Interaction / Change color or Texture
Hello Dear All,
First of all i would like to many thanks this guys for awesome script and autodesk community for helping:
https://knowledge.autodesk.com/support/vred-products/learn-explore/caas/simplecontent/content/adding...
I`m trying to interact with the object/objects. Aiming shooting (pull trigger and realease) exucuting pyhton command and object change material (color or texture) with vive controller.
I would like to know how to create a button and interaction with that. (viewports for example you can teleport yourself with aiming and shooting in the given script upper link!)
Can someone give me a script sample or tutorial for that purpose please?
Best Regards
Florian.Coenen
Hello @Anonymous
within the example scene you pointed to, you should see the buttons for changing the environment.
The button itself is just a touch Sensor that will execute the Variant Set that is linked to the Sensor.
Within the Vset, you can basically execute a Material Switch state.
So you can create a Material Switch for switching materials and then execute the Material Switch State within a Vset.
This is basically the same like switching the environment and you can use the environment Switch example in the provided scene.
I hope that is helpful.
Florian Coenen
Florian.Coenen
Hello @Anonymous
was my last post a bit helpful?
Or do you have additional questions concerning the topic?
In case my post is helpful, please mark it as solution.
Florian Coenen
Sorry for lately reply, im traveling right now for presentation i`m currently freeze that execution problem when im back i will try and share with you as soon as possible.
Regards
Hello Florian,
After your super definition i found a solution thank you very much..
This video tutorial also helpful for this solution..
https://www.youtube.com/watch?v=LbKBOTIVVl0
Best Regards
