Adding VR-Collaboration in VRED for the HTC VIVE
Shawn_Collins-Lopez
Shawn_Collins-Lopez
Trying to get the VRED_OpenVR_Scripts+Collaboration.vpb to work.
https://knowledge.autodesk.com/support/vred-products/learn-explore/caas/simplecontent/content/adding...
Have a local network with two computers on it but can’t get the Vred scene to work, keep getting the following error message on both machines.
Error message: socket.error: [Errno 10061] No connection could be made because the target machine actively refused it
Even when I hit the “S” key in Vred Pro as a test it just freezes up…
I have followed the IP instructions and watched the Car Design News webinar many times.  I can Remote Connect through both machines so the network is working.  Can’t get the scene to connect to each other…
http://cardesignnews.com/articles/webinars/2016/10/autodesk-vred-virtual-reality
Any tips to get this running like the Car Design News demo would be great!
dlincol1
Are both Web Servers enabled in the preferences under WebInterface Module?
Dan
Shawn_Collins-Lopez
No they are not.  I will enable the Web Servers on both machines and give that a shot...
Shawn_Collins-Lopez
Yes that fixed the problem.  The collaboration scene is working now... Thank you!
Greetings,
I am trying to get this collaborate system working but so far I have been unsuccessful:
The ports are open, the server is running but when I start collaboration, the views just become jumpy and start to move and shift around in ways that make me nauseous.
Any ideas?
-Nathan
The terminal has the following output when I run the script provided:
python cmd: 'updateOther([0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0])'
Traceback (most recent call last):
  File "<string>", line 1, in <module>
NameError: name 'updateOther' is not defined
The other machine repeats this:
vrNodePtr::setTransformMatrix : Node pointer == NullFC!
vrNodeUtils::getTransformNodeRotation Node == NULL!
vrNodeUtils::getTransformNodeScale Node == NULL!
vrNodeUtils::setTransformNodeRotation: node == NullFC!
I am not sure what to do with this information.
Any help is greatly appreciated.
-Nathan
