VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Clip not working
4 REPLIES 4
matej.zrncik
453 Views, 4 Replies
Clip not working
Hello, I'm having an issue where my clip that I created in Vred stops working after restarting the application. I animate some translation to a nodes with curve editor, save curves into blocks and put blocks into a clip. Everything works fine until I turn the Vred off and back on. After turning the Vred on my clip isn't doing anything but the blocks still work.
Does anyone know how to solve this issue ? I would be very thankful.
Labels (4)
4 REPLIES 4
Hi, are the blocks you are using coming from a referenced node?
i can't see the scnenegraph but the save "double" bar make me think about that.
i ask because clip animations are not (i hope yet...) supported.
https://help.autodesk.com/view/VREDPRODUCTS/2021/ENU/?guid=VRED_References_html#smart-and-smart-sour...
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Yes it was coming from an refernced node. I've unreferenced it and now it's working prefectly !
Thank you.
Hello Christian,
I am facing the same issue where my clip that I created in Vred stops working after restarting the application. I animate some translation to a nodes with curve editor, save curves into blocks and put blocks into a clip. Everything works fine until I turn the Vred off and back on. After turning the Vred on my clip isn't doing anything but the blocks still work.
May I know how to unreference curve and blocks in clip maker?
Hi references are on nodes, not clips.
You have to manage references from the scenegraph and\or the reference Editor
Best
Chris
