Hello, I'm having an issue where my clip that I created in Vred stops working after restarting the application. I animate some translation to a nodes with curve editor, save curves into blocks and put blocks into a clip. Everything works fine until I turn the Vred off and back on. After turning the Vred on my clip isn't doing anything but the blocks still work.
Does anyone know how to solve this issue ? I would be very thankful.
Solved by Christian_Garimberti. Go to Solution.
Hi, are the blocks you are using coming from a referenced node?
i can't see the scnenegraph but the save "double" bar make me think about that.
i ask because clip animations are not (i hope yet...) supported.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Yes it was coming from an refernced node. I've unreferenced it and now it's working prefectly !
Thank you.
