Hi All,
Has anyone tried batch rendering with render passes? From my testing batch render (Full RT GI, no tonemap .EXR) doesn't write out any passes whereas the same file rendered directly (just hitting the render button) will. Am I missing something?
BTW searching the online help PDF for "render queue" has ZERO hits. Coincidentally the Python Docs Help won't launch from the help menu so I can't even see if I can hack in a python script to sort it.
c
Solved by alexander.grasse. Go to Solution.
Can I assume that because no one has answered your batch file renders are writing out render passes as expected?
please answer with either a yes or no 🙂
cheers
c
What do you mean by Batch Render? Do you mean via the Render Queue?
Render passes were not supported when rendering via the render queue in the initial 2015 release but I believe were added in in 2015 Sp1.
What version of vred are you using?
Hi there,
the renderpasses was added to SP2 together with the renderqueue
cheers
Alex
great, thats the answer i needed, we're running SP1 here.
Will action an update asap
cheers
c
