Write text with limited decimal places
I am trying to put a bearing and distance on every line in a drawing with 3 decimal places on the distance.
I have got the routine to save the needed values but when I write them to text the distance has a bunch of trailing zeros. I need to limit the decimal places to 3.
(setq Dist (getpropertyvalue line "length"))  ;line is set to an entity from a defined selection set
(Dist+ (atof (rtos dist 2 3)))      ;This should round the value to 3 decimal places
(command "_.text" "s" "micro" "j" "m" Dpoint TxtHt AngDMS Dist+) ;Dpoint, TxtHt, AngDMS are all defined parameters
The printed text is rounded to 3 decimal places but still prints the trailing zeros.
How can I limit the zeros?
_gile
Have a look at the DIMZIN system variable.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
dlanorh
Posting the complete lisp might help solve the issue your having.
I am not one of the robots you're looking for
scot-65
Text accepts a string input for the value.
I believe ATOF does not belong there [alpha to floating decimal].
(setq Dist (rtos (getpropertyvalue line "length") 2 3))
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
