Windows in the AutoLiSP Editor Keep Shrinking
mgorecki
mgorecki
Whenever I change from one text window to another in the AutoLiSP editor, the window that I change to shrinks a little bit.  Over time I have to stretch the window back to a usable size.
The original fix was to use the Registry Editor by changing the PaddedBorderWidth to 0 under Computer\HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics.
I've posted this before and when using AutoCAD Mechanical 2018 (Vanilla) the solution worked.  I'm now using AutoCAD Mechanical (Vanilla) and even though I change the PaddedBorderWidth to 0, relaunch AutoCAD and the LiSP editor, the windows keep shrinking.
I'm using Windows 11.
If anyone else has this issue and fixed it, please let me know.
BlackBox_
Autodesk is aware of the undesired behavior and isn't planning to fix VLIDE, AFAIK.
The 'solution' moving forward, is to instead use VS Code with the AutoLISP Extension.
HTH
[Edit] - Love Alf! Haha
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
paullimapa
What is your AutoCAD Mechanical version you're using now?
Paul Li
IT Specialist
@The Office
mgorecki
oops, my bad, I meant to include AutoCAD 2024.
mgorecki
I would, but I really like being able to debug in real time.  Maybe I just haven't figured out how with VS Code.
paullimapa
Using VS Code link @BlackBox_ provided in previous post you should be able to install the Debug feature :
Paul Li
IT Specialist
@The Office
tramber
Didn't know about REGEDIT ! Glad to learn and to give it a try. I guess I need to restart.
It's been years that I ALT+F6 😉
