Why the if condition can not be run?
skchui6159
Message 1 of 9
skchui6159
(vl-load-com)
(setq links "C:/sdsd/sdff/ppp")
(if (=(vl-string-search "//" links) F)
(vl-string-subst "//" "/" links)
(print links)
I want to subst all the "//" to "/". The condition of "if" is satisfactory, why nothing happen? Anyone help?
Accepted solutions (3)
Replies (8)
Message 2 of 9
emilio24DRY
Is this within a lisp routine that you have created? If so, it might be beneficial to see all the code for reference.
Message 3 of 9
Kent1Cooper
What's F?
Kent Cooper, AIA
Message 4 of 9
BeKirra
@Kent1Cooper
Guess OP means "F = false".
If so, here is an approach...
(print links)
Try this:
(if (not (vl-string-search "//" links)
Hi @skchui6159
AS @emilio24DRY mentioned, you might need to show us the entire code.
I suspect you also need to specify what will be happen if (vl-string-search "//" links) is true
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 5 of 9
Kent1Cooper
[Missing a right parenthesis]
(if (not (vl-string-search "//" links))
Kent Cooper, AIA
Message 6 of 9
paullimapa
If you want to replace all instances of "/" with "//" in string "C:/sdsd/sdff/ppp" I'd use this routine:
; aec_replace function to find & replace multiple instances
; https://www.cadtutor.net/forum/topic/68245-find-and-replace-multyple-letters/
 (defun aec_replace (new old string / pos)
  (while (setq pos (vl-string-search old string pos))
   (setq string (vl-string-subst new old string pos)
         pos    (+ pos (strlen new))
   ) ; setq
  ) ; while
  string
 ) ; defun
then:
(setq newlinks (aec_replace "//" "/" links))
!newlinks would return:
"C://sdsd//sdff//ppp"
Paul Li
IT Specialist
@The Office
Message 7 of 9
pbejse
@skchui6159 wrote:
(vl-load-com)
(print links)
This return value for this line is an integer, so ensure that variable F is an integer, otherwise the condition will never evaluate to True
If links  variable value is from a path, the line above will always be 2, unless you include a starting position for vl-string-search
Also this line will never move forward, as only the first instance will change when used on your example
You should also use vl-string-subst with a start-position argument or jsut simple using while function
Putting them all together
  (while (vl-string-search "/" links)
	(setq links (vl-string-subst "\\" "/" links))
or via subfunction
(defun backtoforwardslash (links)
  links
_$ (backtoforwardslash  "C:/sdsd/sdff/ppp")
"C:\\sdsd\\sdff\\ppp"
HTH
Message 8 of 9
pbejse
Also
(defun SingleToDouble (links)
  ((lambda (p)
     (while (Setq p (vl-string-search "/" links (+ p 2)))
       (setq links (vl-string-subst "//" "/" links p))
     links
    0
_$ (SingleToDouble "C:/sdsd/sdff/ppp")
_$
HTH
Message 9 of 9
komondormrex
you do not need to find and replace double slash in the links, cause that string goes fine for file paths which is strings in autolisp.
Command: (findfile "C:/Program Files/Autodesk/AutoCAD 2022/acad.exe")
"C:\\Program Files\\Autodesk\\AutoCAD 2022\\acad.exe"
but backslash is a different story. it won't work singularly in pathing because it is special character in autolisp language and in order to get it as it is you must double it. see return of findfile above.
