Cell contents to Mtext (small steps for a bigger project)
christine_caga-anan
Message 1 of 10
christine_caga-anan
Hi everyone, I am new to using LISP, and I can't find a lisp file that works on my end.
I just want to create a lisp that can automate my workflow. It is a bit complex automation but I want to start first by getting the content of a selected cell and then changing the mtext's content with the copied value.  Hope that you guys/girls can help me with this. Thank you
Replies (9)
Message 2 of 10
komondormrex
hey,
which mtext exactly?
Message 3 of 10
pbejse
@christine_caga-anan wrote:
... but I want to start first by getting the content of a selected cell and then changing the mtext's content with the copied value.
Hi @christine_caga-anan Welcome to this forum.
Are you referring to ACAD_TABLE object? what is the source of the "copied value"?
Message 4 of 10
h_s_walker
Here is the OPs original post in the LT forums. Please note that she only uses LT, so no commands which don't work in LT please.
Solved: Visual LISP, AutoLISP and General Customization - Autodesk Community - AutoCAD LT
Howard Walker
Left Handed and Proud
Message 5 of 10
pbejse
Good to know that bit information @h_s_walker , thanks
@christine_caga-anan  Is it an ACAD_TABLE where you're referring to  cell?
Message 6 of 10
christine_caga-anan
Yes, for the first step, I would like to use the Acad Table cell content, then copy that content to an Mtext by running a lisp,
My goal here is to link that acad table to a datalink (excel) and use the contents of the cell to select the visibility states of a specific block that is also on the acad table. (hope you could picture what's goal)
Message 7 of 10
christine_caga-anan
Message 8 of 10
christine_caga-anan
Hi Komodormrex,
but for now, I would like to copy first a value/text from a cell (acad table) then use that to change the content of an Mtext.
Message 9 of 10
Sea-Haven
Ok 1st for clarification you have access to LISP, so LT 2024 at least.
A function called Hit test it reads a cell in a table by just clicking inside the table cell.
;; Example shows how to pick a single table cell on screen and change its value.
;; This example demonstrates the ActiveX properties/methods HitTest,
;; GetCellType, GetText and SetText.
(defun SelectTableCell ( / pick vHeight vWidth lwrLeft uprRight vector
                                           SS_TABLES cnt eMax  cellValueOrg)
  ;; Ask the user for a point on screen
  (if (/= (setq pick (vlax-3d-point (getpoint "\nSelect Cell to START sum from: "))) nil)
    (progn
      ;; Get the corners of the screen display to build our selection set
      (setq vHeight (getvar "viewsize"))
      (setq vWidth (* (/ (nth 0 (getvar "screensize")) (nth 1 (getvar "screensize"))) vHeight))
      (setq lwrLeft (list (- (nth 0 (getvar "viewctr")) (/ vWidth 2)) (- (nth 1 (getvar "viewctr")) (/ vHeight  2)) 0))
      (setq uprRight (list (+ (nth 0 (getvar "viewctr")) (/ vWidth 2)) (+ (nth 1 (getvar "viewctr")) (/ vHeight  2)) 0))
      ;; Get the current display orientation
      (setq vector (vlax-make-safearray vlax-vbDouble '(0 . 2)))
      (vlax-safearray-fill vector '(1 1 1))
      (setq vector (vlax-make-variant vector))
      ;; Select all the table objects visible on screen
      (if (setq SS_TABLES (ssget "C" lwrleft uprright (list (cons 0 "ACAD_TABLE"))))
        (progn
          (setq cnt 0
                eMax (sslength SS_TABLES)
          ;; Step through all the items in the selection set
          (while (> eMax cnt)
            ;; Geta table object from the selection set
            (setq tableObj (vlax-ename->vla-object (ssname SS_TABLES cnt)))
            ;; Return values for what cell was picked in
            (setq row 0
                  col 0)
            ;; Below is also a sample to see if a valid cell is picked
            ;; (vla-select table pick vector vector 5 5 :vlax-false 'row 'col)
            ;; Check to see if a valid cell was picked
            (if (= (vla-hittest tableObj pick vector 'row 'col) :vlax-true)
              (progn
                ;; Get out of the loop
                (setq cnt (1+ eMax))
                ;; Check to see what the Cell Type is (Text or Block)
                (if (= (vla-GetCellType tableObj row col) acTextCell)
                                    ;; Let's get the value out exit with row - col
                    (setq cnt eMax)
            (setq cnt (1+ cnt))
 (princ)
) ; defun
Message 10 of 10
christine_caga-anan
Thanks Sea-haven, I will look into that hit test.
