Why dose vlax-get-property only accept single word strings in this lisp?
Satoews
Satoews
This is on civ3d but hopfully I am just missing a step in getting this to work in the programming:
(defun c:lbcng (/ ss i parcelLabel vlaObj lbl)
(vl-load-com)
  (setq ss (ssget))
  (setq i (sslength ss))
  (while (not (minusp (setq i (1- i))))
	   (setq parcelLabel (ssname ss i))
	   (setq vlaObj (vlax-ename->vla-object parcelLabel))
       (setq lbl (vlax-get-property vlaObj 'LineLabelStyleName))
	     (if (= lbl "Lot Labels")
		   (vlax-put-property vlaObj 'LineLabelStyleName "Lot Labels Plus Minus" )
           (vlax-put-property vlaObj 'LineLabelStyleName "CW house label" )))
(princ)
So at the end of the lisp vlax-put-property vlaobj 'linelabelstylename will work if i put in "standard" but will not work with any argument strings more than one word.
Thanks in advance!
Shawn T
dgorsman
You should check the object model for what you are attempting to modify.  It may have a restriction on what it can be set to.  The property name (LineLabelStyleName) would suggest it is looking for a style name which may check for valid names, or the style names themselves may not work with spaces or special characters.
Satoews
;   LineLabelStyle = #<VLA-OBJECT IAeccLabelStyle 000000003ef43570>
;   LineLabelStyleName = "Lot Labels"
I think it is showing the space as invalid, any way for myself to use Linelabelstyle at all? Tried different ways to input but it was shown as invalid.
Shawn T
Satoews
Ok troubleshot it some more and found that.
will return any label style in any list, but. . .
(vlax-put-property vlaObj 'LineLabelStyleName "changetothis" )
will only change from the list of the general 'linelabelstylename, thats why standard worked.
I need to get to the parcel list of the 'linelabelstylename.
So instead of
general - label styles - line - "standard"
I need
Parcel - label styles - line - "Lot Labels Plus Minus"
Shawn T
Satoews
So after a night of searching I was able to piece together this.
(defun C:changelabel ( / ss i parcelLabel vlaObj *acad* verstr c3d c3ddoc parcel_label_styles parcel_line_label_styles styl )
(if (setq ss (SSGET))
(progn
(setq *acad* (vlax-get-acad-object))
(setq verstr (strcat "HKEY_LOCAL_MACHINE\\"
(if vlax-user-product-key
(vlax-user-product-key)
(vlax-product-key)
verstr (vl-registry-read verstr "Release")
verstr (substr verstr
1
(vl-string-search
verstr
(+ (vl-string-search "." verstr) 1)
C3D (vla-getinterfaceobject
*acad*
(strcat "AeccXUiLand.AeccApplication." verstr)
(setq C3Ddoc (vlax-get c3d 'activedocument))
(setq parcel_label_styles (vlax-get c3ddoc 'parcellabelstyles))
(setq parcel_line_label_styles (vlax-get parcel_label_styles 'linelabelstyles))
(vlax-for x parcel_line_label_styles
(if
(eq (vlax-get x 'name) "Lot Labels Plus Minus")
(setq styl x)
(vlax-put-property vlaobj 'linelabelstyle styl)
(vlax-release-object c3ddoc)
(vlax-release-object c3d)
(princ)
Part from here (post 9 of 10) and part from here (post 6 of 7). Works to adjust parcel label styles in a selection set, just change "lot labels plus minus" to whatn you'd like.
Shawn T
brianchapmandesign
Am curious Tornac, why wouldn't you just select similar and change in the properties?
"Very funny, Scotty. Now beam down my clothes.
Satoews
Select similar would grab every label if I'm not mistaken. Changing them in properties also takes time, this lisp makes it much faster in comparison.
Shawn T
