scripts WRITING HELP
I HAVEN'T DONE ANY REAL SCRIPT WRITING SO I AM LOOKING FOR A SCRIPT THAT WHEN YOU CLOSE THE DRAWING IT WILL.
RETURN TO PAPERSPACE
ZOOM EXTENTS
SET LAYER TO ZERO
SET VISRETAIN TO 1
PURGE THE DRAWING
LOCK VIEWPORTS
SAVE DRAWING
CLOSE
THANK YOU
tcorey
I don't think you want a script. I think you want a LISP routine with a reactor that is triggered by Close (or quit?).
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Do you have a lisp routine for it
JN05
Good morning,
The topic is very interesting. Did someone to write something like that or find a solution in the form of Lisp?
Tomasz Stawarz, Co-owner
ZNAK Gdańsk sp. z o.o.
Gdańsk, PL.
Tomasz Stawarz is co-founder and co-owner of ZNAK Gdańsk sp. z o.o., Gdańsk, PL. Tom's speciality is Civil Infrastructure and has been working with AutoCad since 1997.
devitg
you ask for
ZOOM EXTENTS
SET LAYER TO ZERO
SET VISRETAIN TO 1
PURGE THE DRAWING
LOCK VIEWPORTS
SAVE DRAWING
CLOSE
Should it be ?
RETURN TO MODEL SPACE
Can be purge ALL , ??
Maybe , if you can upload a sample DWG, will be easy to help.
