Why Does the LSP Suddenly Lock Up When "Load Select" is Picked?
mgorecki
mgorecki
Does anyone know why when debugging (line by line), suddenly the top of the page says "...loading" and then it locks up and I can't proceed.
This happens all the time.  It's a simple line like (setq something 2.3).  I highlight it and from the menu bar I pick "load selection".  Most of the time it just does it, but sometimes (too often) it locks up and goes into "loading..." mode and I have to kill the code and save it because it never stops loading.
This is AutoCad 2018.
Sea-Haven
If your copy and pasting lines of code to command line, I do all the time, you need to remove fancy indenting the use of tab will cause problems, same as the last character per line is ) no remarks or spaces afterwards.
Ok
no go
mgorecki
I don'believe I had spa ces or anything like that, but I will be extra vigilant to make sure that doesnt happen.  Thanks for letting me know about those things.
ВeekeeCZ
Never did, never happend.
