Message 1 of 10
Hello people,
I am making a simple program that will create a folder on the C: Drive called AutoLisp and then places a few AutoLisps in that folder.
The next step I am having an issue with... I need to access Support File Search Path in Options menu, and add the newly created directory "C:\AutoLisp"
How can I do that from outside of AutoCAD? Is there some INI, XML, or other file type that contains the support directories? Maybe its in the windows registry?
Thank you for your time đ
The definition of insanity is doing the same thing over and over again and expecting different results
