Automatic Block Break - Add Select Similar Option
joel.bennettFVVY2
joel.bennettFVVY2
I could use some help modifying Lee Mac's Automatic Block Break LISP to allow the selection of similar blocks. Currently you can select a single block (ABBE) or (ABBS) multiselect blocks. I need to select all blocks identical to  right clicking "select similar" or by entering the block Name which then selects all instances of that block with in a drawing.
Thanks in advance
Link to LISP
http://www.lee-mac.com/autoblockbreak.html
Code from LISP file
;;---------------------=={ Automatic Block Break }==--------------------;;
;; This program enables the user to insert a block at a specified ;;
;; point, with surrounding geometry trimmed to the rectangular outline ;;
;; of the block. Optionally, the program will automatically rotate ;;
;; the block to align with a curve object passing through the block ;;
;; insertion point. ;;
;; The program first prompts the user to select a block to insert. At ;;
;; this prompt the user may select a block from the drawing, or type ;;
;; 'Browse' to browse for a drawing file to insert. The user may also ;;
;; alter the program rotation setting by typing 'Rotation' at the ;;
;; prompt. ;;
;; Following a valid response, the program prompts the user to specify ;;
;; an insertion point for the block. ;;
;; If a curve object (Arc, Elliptical Arc, Ellipse, Circle, Line, ;;
;; XLine, Spline, LWPolyline or Polyline) is detected at the block ;;
;; insertion point and the program rotation setting is enabled, the ;;
;; inserted block is automatically rotated to align with the curve. ;;
;; All surrounding compatible objects found to intersect with the ;;
;; inserted block are then trimmed to the rectangular block outline. ;;
;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;;
;; Version 1.0 - 2010-11-22 ;;
;; - First release. ;;
;; Version 1.1 - 2011-02-07 ;;
;; - Entire program rewritten to allow subfunction to be called with ;;
;; block object argument. ;;
;; - Multiple intersecting objects are now trimmed. ;;
;; Version 1.2 - 2011-02-08 ;;
;; - Changed block insertion to Visual LISP InsertBlock method. ;;
;; - Added calling functions to trim blocks in-situ (ABBE / ABBS). ;;
;; Version 1.3 - 2011-08-03 ;;
;; - Altered method used to create bounding polyline to exclude ;;
;; attributes when trimming objects surrounding block. ;;
;; - Objects surrounding blocks whose insertion point does not lie on ;;
;; a curve are now also trimmed. ;;
;; Version 1.4 - 2011-09-30 ;;
;; - Added option to enable/disable automatic block rotation. ;;
;; - Updated code formatting. ;;
;; Version 1.5 - 2013-03-04 ;;
;; - Fixed bug causing program to attempt to break MLines. ;;
;; - Added new LM:blockboundingbox function to correctly calculate ;;
;; the bounding box of Dynamic Block references. ;;
;; - Entire program rewritten. ;;
;; Version 1.6 - 2013-10-01 ;;
;; - Fixed a bug causing the program to return an error if an object ;;
;; intersects the block bounding box at only one point. ;;
;; Version 1.7 - 2014-11-22 ;;
;; - Changed the method used to detect objects located at the block ;;
;; insertion point when determining the angle for automatic ;;
;; block rotation. ;;
;; Version 1.8 - 2017-10-09 ;;
;; - Revised calculation of block bounding box to ignore objects ;;
;; residing on frozen layers. ;;
;; - Added option to specify block name at command-line. ;;
;; Version 1.9 - 2020-11-14 ;;
;; - Revised calculation of block rotation angle to account for ;;
;; insertion points located at the end points of the supplied curve. ;;
(defun c:abb ( / *error* blk obj ins sel tmp )
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(cond
( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))
(princ "\nCurrent layer locked.")
( (progn
(while
(not
(progn
(setvar 'errno 0)
(initget "Browse Name Rotation")
(princ (strcat "\nAutomatic Block Rotation: " (getenv "LMac\\ABBRotation")))
(setq sel
(entsel
(strcat "\nSelect Block [Browse/Name/Rotation]"
(if (= "" (setq blk (getvar 'insname)))
(strcat " <" blk ">: ")
(cond
( (= 7 (getvar 'errno))
(prompt "\nMissed, Try Again.")
( (null sel)
(not (if (= "" blk) (setq blk nil)))
( (= "Rotation" sel)
(initget "ON OFF")
(setenv "LMac\\ABBRotation"
(cond
( (getkword
(strcat "\nAutomatic Block Rotation [ON/OFF] <"
(getenv "LMac\\ABBRotation") ">: "
( (getenv "LMac\\ABBRotation") )
nil
( (= "Name" sel)
(while
(not
(or
(setq tmp
(getstring t
(strcat "\nSpecify block name"
(if (= "" blk) ": " (strcat " <" blk ">: "))
(tblsearch "block" tmp)
(princ (strcat "\nBlock \"" tmp "\" is not defined in the current drawing."))
(cond
( (/= "" tmp) (setq blk tmp))
( (/= "" blk))
( (= "Browse" sel)
(setq blk (getfiled "Select Block" "" "dwg" 16))
( (listp sel)
(if (/= "INSERT" (cdr (assoc 0 (entget (car sel)))))
(prompt "\nObject must be a block.")
(setq obj (vla-copy (vlax-ename->vla-object (car sel)))
blk (LM:blockname obj)
(not (or blk obj))
( (setq ins (getpoint (strcat "\nSpecify insertion point for " (vl-filename-base blk) " block: ")))
(LM:startundo (LM:acdoc))
(if (null obj)
(setq obj
(vla-insertblock
(vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
(vlax-3D-point (trans ins 1 0))
blk
1.0
1.0
1.0
(angle '(0.0 0.0 0.0) (trans (getvar 'ucsxdir) 0 (trans '(0.0 0.0 1.0) 1 0 t) t))
(if blk (setvar 'insname (vl-filename-base blk)))
(vla-put-insertionpoint obj (vlax-3D-point (trans ins 1 0)))
(LM:autoblockbreak (vlax-vla-object->ename obj) (= "ON" (getenv "LMac\\ABBRotation")))
(princ)
;;----------------=={ Automatic Block Break Existing }==----------------;;
;; This program enables the user to select an existing block and trim ;;
;; all surrounding geometry to the rectangular outline of the block. ;;
;; Optionally, the program will automatically rotate the selected ;;
;; block to align with a curve object passing through the block ;;
;; At the block selection prompt, the user may also alter the program ;;
;; rotation setting by typing 'Rotation' when prompted. ;;
;; insertion point of the selected block and the program rotation ;;
;; setting is enabled, the block is automatically rotated to align ;;
;; with the curve. ;;
;; selected block are then trimmed to the rectangular block outline. ;;
(defun c:abbe ( / *error* enx sel )
(princ)
(while
(progn
(setvar 'errno 0)
(initget "Rotation")
(setq sel (entsel "\nSelect Block to Trim [Rotation]: "))
(cond
(princ "\nMissed, Try Again.")
(initget "ON OFF")
(cond
( (getkword
( (= 'ename (type (car sel)))
(cond
( (/= "INSERT" (cdr (assoc 0 (setq enx (entget (car sel))))))
(princ "\nObject must be a block.")
( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 enx)))))))
(princ "\nSelected block is on a locked layer.")
( t
(LM:AutoBlockBreak (car sel) (= "ON" (getenv "LMac\\ABBRotation")))
t
(princ)
;;---------------=={ Automatic Block Break Selection }==----------------;;
;; This program enables the user to select multiple existing blocks ;;
;; and automatically trim all surrounding geometry to the rectangular ;;
;; outline of each block. Optionally, the program will automatically ;;
;; rotate each block in the selection to align with curve objects ;;
;; detected to pass through the block insertion point. ;;
(defun c:abbs ( / *error* inc rot sel )
(princ)
(setq rot (= "ON" (getenv "LMac\\ABBRotation")))
(if (setq sel (ssget "_:L" '((0 . "INSERT"))))
(progn
(repeat (setq inc (sslength sel))
(LM:AutoBlockBreak (ssname sel (setq inc (1- inc))) rot)
(princ)
;;---------------=={ Automatic Block Break SubFunction }==--------------;;
;; Upon calling the function with a VLA Block Reference Object ;;
;; argument, the function will trim all surrounding compatible ;;
;; geometry found to intersect with the rectangular outline of the ;;
;; supplied block reference. ;;
;; Furthermore, if a curve object is detected to pass through (or in ;;
;; the vicinity of) the block insertion point and the rotation flag ;;
;; argument holds a non-nil value, the supplied block reference is ;;
;; rotated to align with the curve. ;;
;; Arguments: ;;
;; ent - Block Reference Entity ;;
;; rot - Rotation flag (if T, block is aligned to curve) ;;
(defun LM:autoblockbreak ( ent rot / *error* _furthestapart ang bbx brk cmd crv di1 di2 enx idx ins int lst ply sel tmp )
(if (and (= 'vla-object (type ply)) (vlax-write-enabled-p ply))
(vla-delete ply)
(if (= 'int (type cmd))
(setvar 'cmdecho cmd)
(princ)
(defun _furthestapart ( lst / dis mxd out pt1 pt2 )
(setq mxd 0.0)
(while (setq pt1 (car lst))
(foreach pt2 (setq lst (cdr lst))
(if (< mxd (setq dis (distance pt1 pt2)))
(setq mxd dis
out (list pt1 pt2)
out
(if (and (= 'ename (type ent))
(setq enx (entget ent))
(= "INSERT" (cdr (assoc 0 enx)))
(progn
(if
(and
rot
(setq bbx (LM:blockboundingbox (vlax-ename->vla-object ent)))
(setq sel
(ssget "_C"
(trans (car bbx) 0 1)
(trans (caddr bbx) 0 1)
'((0 . "ARC,ELLIPSE,CIRCLE,LINE,XLINE,SPLINE,*POLYLINE"))
(progn
(setq ins (trans (cdr (assoc 10 enx)) ent 0)
crv (ssname sel (1- (sslength sel)))
di1 (distance ins (vlax-curve-getclosestpointto crv ins))
(repeat (setq idx (1- (sslength sel)))
(setq tmp (ssname sel (setq idx (1- idx))))
(if (< (setq di2 (distance ins (vlax-curve-getclosestpointto tmp ins))) di1)
(setq di1 di2
crv tmp
(< di1 1e-4)
(setq par (vlax-curve-getparamatpoint crv (vlax-curve-getclosestpointto crv ins)))
(cond
( (equal par (vlax-curve-getendparam crv) 1e-8)
(setq par (vlax-curve-getparamatdist crv (- (vlax-curve-getdistatparam crv par) 1e-3)))
( (equal par (vlax-curve-getstartparam crv) 1e-8)
(setq par (vlax-curve-getparamatdist crv (+ (vlax-curve-getdistatparam crv par) 1e-3)))
( t )
(setq der (vlax-curve-getfirstderiv crv par))
(setq ang (angle '(0.0 0.0 0.0) (trans der 0 (cdr (assoc 210 (entget crv))))))
(or (<= ang (/ pi 2.0))
(< (/ (* 3.0 pi) 2.0) ang)
(setq ang (+ ang pi))
(vla-put-rotation (vlax-ename->vla-object ent) ang) ;; VL used to account for attributes
(if
(and
(setq sel
(ssget "_C"
(progn
(setq ply
(entmakex
(append
(list
'(000 . "LWPOLYLINE")
'(100 . "AcDbEntity")
'(100 . "AcDbPolyline")
'(090 . 4)
'(070 . 1)
(cons 38 (cadddr (assoc 10 enx)))
(mapcar '(lambda ( p ) (mapcar '+ (cons 10 (trans p 0 ent)) '(0 0 0))) bbx)
(list (assoc 210 enx))
(repeat (setq idx (sslength sel))
(setq ent (ssname sel (setq idx (1- idx))))
(if (setq int (LM:Intersections (vlax-ename->vla-object ent) ply acextendthisentity))
(setq lst (cons (cons ent int) lst))
(vla-delete ply)
(setq cmd (getvar 'cmdecho))
(setvar 'cmdecho 0)
(foreach int lst
(if (setq brk (_furthestapart (cdr int)))
(command
"_.break" (list (car int) (trans (car brk) 0 1)) "_F"
"_non" (trans (car brk) 0 1)
"_non" (trans (cadr brk) 0 1)
(princ)
;; Intersections - Lee Mac
;; Returns a list of all points of intersection between two objects.
;; obj1,obj2 - [vla] VLA-Objects with intersectwith method applicable
;; mode - [int] acextendoption enum of intersectwith method
;; Returns: [lst] List of 3D WCS intersection points, else nil
(defun LM:intersections ( obj1 obj2 mode / l r )
(setq l (vlax-invoke obj1 'intersectwith obj2 mode))
(repeat (/ (length l) 3)
(setq r (cons (list (car l) (cadr l) (caddr l)) r)
l (cdddr l)
(reverse r)
;;-------------------=={ Block BoundingBox }==----------------;;
;; Returns a point list describing a rectangular frame ;;
;; bounding all geometry of a supplied block reference. ;;
;; Excludes Text, MText & Attribute Definitions. ;;
;; Author: Lee Mac, Copyright © 2013 - www.lee-mac.com ;;
;; Arguments: ;;
;; blk - VLA Block Reference Object ;;
;; Returns: WCS Point list describing boundingbox of block ;;
(defun LM:blockboundingbox ( blk / bnm llp lst urp )
(setq bnm (strcase (vla-get-name blk)))
(cond
( (setq lst (cdr (assoc bnm LM:blockboundingbox:cache))))
( (progn
(vlax-for obj (vla-item (LM:acblk) bnm)
(cond
( (= "AcDbBlockReference" (vla-get-objectname obj))
(setq lst (append lst (LM:blockboundingbox obj)))
( (and
(= :vlax-true (vla-get-visible obj))
(not (wcmatch (vla-get-objectname obj) "AcDbAttributeDefinition,AcDb*Text"))
(vlax-method-applicable-p obj 'getboundingbox)
(= :vlax-false (vla-get-freeze (vla-item (LM:aclyr) (vla-get-layer obj))))
(not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'llp 'urp))))
(setq lst (vl-list* (vlax-safearray->list llp) (vlax-safearray->list urp) lst))
lst
(setq lst (mapcar '(lambda ( fun ) (apply 'mapcar (cons fun lst))) '(min max)))
(setq lst
(list
(car lst)
(list (caadr lst) (cadar lst))
(cadr lst)
(list (caar lst) (cadadr lst))
(setq LM:blockboundingbox:cache (cons (cons bnm lst) LM:blockboundingbox:cache))
(apply
(function
(lambda ( m v )
(mapcar (function (lambda ( p ) (mapcar '+ (mxv m p) v))) lst)
(refgeom (vlax-vla-object->ename blk))
;; RefGeom (gile)
;; Returns a list which first item is a 3x3 transformation matrix (rotation,
;; scales, normal) and second item the object insertion point in its parent
;; (xref, block or space)
;; Argument : an ename
(defun refgeom ( ent / ang ang mat ocs )
ang (cdr (assoc 050 enx))
ocs (cdr (assoc 210 enx))
(list
(setq mat
(mxm
(mapcar '(lambda ( v ) (trans v 0 ocs t))
(1.0 0.0 0.0)
(0.0 1.0 0.0)
(0.0 0.0 1.0)
(mxm
(list
(list (cos ang) (- (sin ang)) 0.0)
(list (sin ang) (cos ang) 0.0)
'(0.0 0.0 1.0)
(list
(list (cdr (assoc 41 enx)) 0.0 0.0)
(list 0.0 (cdr (assoc 42 enx)) 0.0)
(list 0.0 0.0 (cdr (assoc 43 enx)))
(mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
(mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Matrix Transpose - Doug Wilson
(defun trp ( m )
(apply 'mapcar (cons 'list m))
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Block Name - Lee Mac
;; Returns the true (effective) name of a supplied block reference
(defun LM:blockname ( obj )
(if (vlax-property-available-p obj 'effectivename)
(defun LM:blockname ( obj ) (vla-get-effectivename obj))
(defun LM:blockname ( obj ) (vla-get-name obj))
(LM:blockname obj)
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
;; Block Collection - Lee Mac
;; Returns the VLA Block Collection Object
(defun LM:acblk nil
(eval (list 'defun 'LM:acblk 'nil (vla-get-blocks (LM:acdoc))))
(LM:acblk)
;; Layer Collection - Lee Mac
;; Returns the VLA Layer Collection Object
(defun LM:aclyr nil
(eval (list 'defun 'LM:aclyr 'nil (vla-get-layers (LM:acdoc))))
(LM:aclyr)
(if (null (getenv "LMac\\ABBRotation"))
(setenv "LMac\\ABBRotation" "ON")
(vl-load-com)
(princ
(strcat
"\n:: AutoBlockBreak.lsp | Version 1.9 | \\U+00A9 Lee Mac "
((lambda ( y ) (if (= y (menucmd "m=$(edtime,0,yyyy)")) y (strcat y "-" (menucmd "m=$(edtime,0,yyyy)")))) "2010")
" www.lee-mac.com ::"
"\n:: \"ABB\" - Insert & Break | \"ABBE\"/\"ABBS\" - Break Existing ::"
(princ)
;; End of File ;;
ВeekeeCZ
Well, if SelectSimilar works for you, then why you don't use it? Keep the selection highlighted (selected) and run ABBS...
joel.bennettFVVY2
Sorry I thought I tried that and it did not work. I just re-tried it after your suggestion and it works as desired. Thank you.
