Message 1 of 15
04:41 AM
- Mute
- Permalink
- Report
This code works relatively well, however when I run it for the first time it generates
Error: bad argument type: stringp nilbad argument type: stringp #<FILE internal>
and does not end. I've done it step by step and I don't understand why, any guidance?
;;--------------------- { Get Attribute Value - Lee Mac } --------------------;; ;; ;; ;;------------------------------------------------------------------------------;; ;; Autor: Lee Mac ;; ;;------------------------------------------------------------------------------;; ;; Argumentos: ;; ;; blk - [vla] VLA Block Reference Object ;; ;; tag - [str] Attribute TagString ;; ;;------------------------------------------------------------------------------;; (defun LM:vl-getattributevalue ( blk tag ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes)) ) ;;--------------------- { Set attributevalue - Lee Mac- } --------------------;; ;; ;; ;;------------------------------------------------------------------------------;; ;; Autor: Lee Mac ;; ;;------------------------------------------------------------------------------;; ;; Argumentos: ;; ;; blk - [vla] VLA Block Reference Object ;; ;; tag - [str] Attribute TagString ;; ;; val - [str] Attribute Value ;; ;;------------------------------------------------------------------------------;; (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att )(if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val)))(vlax-invoke blk 'getattributes)) ) ;;------------------------------------------------------------------------------;; (defun c:EXTRELATORIO (/ ss file i blk vatt ratt ip ss2 att1 att2 att3 att4 att5 ) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ) (close file) (vl-file-delete file) (princ) ) (setq ss (ssget '((0 . "INSERT") (66 . 1)(2 . "Poste_Enel,`*U*")))) (setq file (open (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".txt") "w")) (write-line "Numero;Latitude;Longitude;Relatorio" file ) (repeat (setq i (sslength ss)) (setq blk (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (setq vatt '("NUM" "LATITUDE" "LONGITUDE" "RELATORIO")) (setq ratt (mapcar '(lambda (x) (LM:vl-getattributevalue blk x)) vatt)) ;(setq ratt (mapcar '(lambda (x) (vl-some '(lambda ( att ) (if (= (strcase x) (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))) vatt)) <- Melhor! (mapcar 'set '(att1 att2 att3 att4) ratt) (setq ip (vlax-get blk 'insertionpoint)) (setq ss2 (ssget "_C" (mapcar '+ ip '(5 5)) (mapcar '- ip '(5 5)) '((0 . "INSERT")(66 . 1)(2 . "Caixa001,Caixa002,Caixa003,Caixa004,Caixa005,Caixa006")))) (if (/= ss2 nil) (if (= (sslength ss2) 1) (progn (setq blk2 (vlax-ename->vla-object (ssname ss2 0))) (LM:vl-setattributevalue blk2 "IDCX" att1) (setq att5 (LM:vl-getattributevalue blk2 "NOM")) ) ) (setq att5 "") ) (write-line (strcat att1 ";" att2 ";" att3 ";" att4 ";" att5 ) file ) ) (close file) ;(startapp "notepad" "G:\\Meu Drive\\Brisanet Programas\\Desenhos\\Extrator Material\\Teste-.txt") (princ) )
