How to fill Var witch Lisp?
Hi, a little ask..
I need to fill a field like this, but with lisp.
%<\AcVar CustomDP.1º TÍTULO>%
I was trying this, no one works.
(defun c:June()
	(setq '%<\AcVar CustomDP.Nº PLANO>%' "Titulo 1")
Error: Sintaxis error
(defun c:June()
	(setq "%<\AcVar CustomDP.Nº PLANO>%" "Titulo 1")
(defun c:June()
	(setq "CustomDP.Nº PLANO" "Titulo 1")
I hope I have made myself understood
Thanks you.
CodeDing
@Anonymous ,
I use these 2 functions to get / set my custom drawing properties:
(defun GetCustomDwgProp (key / acObj acDoc docProps return num keyVal propVal)
;key - string, representing key value of custom dwgprop to search for
;returns string of dwgprop value if found, or nil
(setq acObj (vlax-get-acad-object))
(setq acDoc (vla-get-ActiveDocument acObj))
(setq docProps (vla-get-SummaryInfo acDoc))
(setq return nil num 0)
(if (and (>= (setq total (vla-NumCustomInfo docProps)) 1)
	 (eq 'STR (type key)))
  (while (< num total)
    (vla-GetCustomByIndex docProps num 'keyVal 'propVal)
    (if (eq (strcase key) (strcase keyVal)) (setq return propVal))
    (setq num (1+ num))
  );while
);if
return
);defun
(defun SetCustomDwgProp (key val / acObj acDoc docProps return num keyVal propVal)
;val - string, representing custom value to be used for the "key" custom dwgprop
;returns t if successful, or nil
	 (eq 'STR (type val)))
      (progn
	(vla-SetCustomByIndex docProps num keyVal val)
	(setq return t)
      );progn
    );if
    (setq num (1+ num))
  );while
);if
return
);defun
Example syntax call:
(defun c:TEST ( / x)
(SetCustomDwgProp "CustomProperty" "CustomValue")
(setq x (GetCustomDwgProp "CustomProperty"))
(alert x)
(princ)
);defun
Hope this helps! Best,
~DD
