Help with Field
Help with Field
DC-MWA
Help with Field
DC-MWA
Been working on a routine to automatically label property lines.
It works but I get xx.0000" in the seconds portion of the label.
I do not know how to fix this. I have attached the lisp code that creates the field. I'm hoping this is a simple mistake on my end.
Thanks for your time!
-dc
cadffm
Start Autocad, start field command, create a field like you want to have it.
Look for the fieldcode in field dialog.
Sebastian
DC-MWA
Well,
That's where I started. But I re-visied it again just now.
I got:
;;;%<\AcObjProp Object(%<\_ObjId 2999039409280>%).Angle \f "%au1">%
The code section is:
"%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-objectid o)) ">%).Angle \\f \"%au1\">%"
So I though maybe %au4 should be %au1.
Didn't work.
ronjonp
Hint: "%au1%pr1" <Depending on precision you want.
Picture for troubleshooting:
DC-MWA
%au4%pr4
Thank you.
ronjonp
@DC-MWA wrote:
%au4%pr4
Thank you.
