where will i get vla funcion?
thsa2501
thsa2501
hii everyone,
kindly hepl me.where will i get vla function such as vla-put-textstring,vla-put-color,vla-getattributes,vla-item
thanks advance
_gile
Hi
'vla' stands for Visual Lisp Automation.  The 'vla' functions are LISP wrappers to access to the AutoCAD COM API properties (vla-get-PropertyName / vla-put-PropertyName) and methods (vla-MethodName) using ActiveX/Automation. These methods ans properties are documented in the ActiveX: Reference Guide of the AutoCAD developper's documentation.
Gilles Chanteau
GileCAD
GitHub
Kent1Cooper
@thsa2501 wrote:
....where will i get vla function ....
If by that you mean how do you make those functions available to use, put this in at the command line:
(vl-load-com)
You can build that into the beginning of any AutoLisp routine definitions that use those functions, to be sure they will be available.
Kent Cooper, AIA
paullimapa
Just do a google search online for
autolisp vla functions
and you’ll find all your answers
Paul Li
IT Specialist
@The Office
john.uhden
@_gile
And God bless Peter Petrov for developing it for R14 as VitalLisp.
I hope Autodesk paid him well.
Anyway, the simple answer would be (vl-load-com).
John F. Uhden
thsa2501
hi gile,
thank you so much a lot
yangguoshe
If you want to get the list of all vla- functions , you can enter vla in vlide's text editor, double-click it, and then Ctrl+shift+space to pop up the function list
