When Centroid is ouside a polyline what is the inside middle point alternative
Message 1 of 11
Hello!
In case of very irregular 2D shapes where Centroid is a point outside a polyline, what is the alternative.
I would like to find an alternative middle point inside the polyline.
Any suggestions?
Thanks in advance + regards,
Lzucco
Replies (10)
Message 2 of 11
Kent1Cooper
For what purpose?  I imagine it could vary a lot depending on what you want to do with/from/to/about the alternate location, and the particular shape of the Polyline.  Maybe the (vlax-curve-getClosestPointTo) function, giving it the actual centroid to find the closest point on the Polyline to?  Of course, that will always be on the edge  of the Polyline, not "inside" it, if that distinction matters to you.
Kent Cooper, AIA
Message 3 of 11
_gile
If you can give an absolutely unambiguous description of what you call "middle point inside the polyline", it should be possible to derive an algorithm from it.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 4 of 11
It is indeed an absolutely ambiguous description and very difficult to define once we can find innumerous irregular polygons shapes in a city map that are the representation of plots of land.
What I'm trying to find is a equidistant middle point inside the polyline that not touch the borders.
Message 5 of 11
devitg
Please upload a sample.dwg, and what is the purpose of such "center"
Message 6 of 11
Attached an example. The irregular shape with has the Centroid outside the polyline is colored.
Message 7 of 11
_gile
You can try offseting inside the boundary, every point on the offset curve should be inside.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 11
_gile
I found a routine I wrote more than 10 years ago. it uses a dichotomic search for the max offset distance according to a fuzz.
(defun MostInnerPoint (obj fuzz / 2d-coord->pt-lst 3d-coord->pt-lst dich-sub len tmp)
  (vl-load-com)
  (defun 2d-coord->pt-lst (lst)
    (if	lst
      (cons (list (car lst) (cadr lst))
	    (2d-coord->pt-lst (cddr lst))
  (defun 3d-coord->pt-lst (lst)
    (if	lst
      (cons (list (car lst) (cadr lst) (caddr lst))
	    (3d-coord->pt-lst (cdddr lst))
  (defun dich-sub (inf sup / of new pts)
    (if	(equal inf sup fuzz)
      (progn
	(setq of  (vlax-invoke obj 'Offset inf)
	      pts (if (= (vla-get-ObjectName (car of)) "AcDbPolyline")
		    (2d-coord->pt-lst (vlax-get (car of) 'Coordinates))
		    (3d-coord->pt-lst (vlax-get (car of) 'ControlPoints))
	(mapcar 'vla-delete of)
	(mapcar
	  (function
	    (lambda (x)
	      (/ x (length pts))
	  (apply 'mapcar (cons '+ pts))
      (progn
	(setq new (/ (+ inf sup) 2.0)
	      of  (vl-catch-all-apply
		    'vlax-invoke
		    (list obj 'Offset new)
	(if (vl-catch-all-error-p of)
	  (dich-sub inf new)
	  (progn
	    (dich-sub new sup)
  (if (and
	(member	(vla-get-ObjectName obj)
		'("AcDbPolyline" "AcDbSpline")
	(vlax-curve-isClosed obj)
	(or (= (vla-get-ObjectName obj) "AcDbPolyline")
	    (vlax-curve-isPlanar obj)
	(setq tmp (vl-catch-all-apply 'vlax-invoke (list obj 'Offset fuzz)))
	(setq len (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj))
	      tmp (car tmp)
	(if (< len
	       (vlax-curve-getDistAtParam tmp (vlax-curve-getEndParam tmp))
	  (setq len (/ len (* -2 pi)))
	  (setq len (/ len (* 2 pi)))
	(not (vla-delete tmp))
    (dich-sub 0.0 len)
(defun c:test (/ ent)
  (and (setq ent (car (entsel)))
       (entmake
	 (list '(0 . "POINT")
	       '(62 . 3)
	       (cons 10
		     (MostInnerPoint (vlax-ename->vla-object ent) 0.01)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 9 of 11
Love this im literaly jumping on my seat! Love from Argentina ❤️
Message 10 of 11
1LandSurveyor
@_gile : Is there a reason to why you start the dichotomic search with the length of the curve divided by 2*pi? I'm just curious.
(dich-sub 0.0 len)
Message 11 of 11
_gile
@1LandSurveyor
I absolutely don't remember. Dividing by 2  seems to work the same.
(setq len (/ len 2.))
(dich-sub 0.0 len)
Gilles Chanteau
GileCAD
GitHub
