I have this awesome LISP from @dlanorh, and now need some new functionality added. Maybe the original creator can help me out? 🙂
In addition to what the LISP already does (calculating the sq ft and entering it in the attribute "Area ="), I would like to assign each polyline a unique ID # in one of the other attributes in that same block. The block is "RoomTagArea" and the attribute is "ID:". (Polylines and blocks are on the same layer.) The unique number would have the prefix "SM" followed by 6-digits starting at "000001". So the end result would look like "ID: SM000001", "ID: SM000002", "ID: SM000003", and so on for the blocks found within each polyline. Is this possible?
I've attached the original LISP and a screenshot of what the blocks should look like after running the LISP. Thanks!
