What should I write in lisp to show specified command in InteractiveMenu?
here
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/scale-in-x-y-bothxy-definied-directio...
is example of lisp in which prompts are shown via Interactive Menu (like in -LAYER, -LINETYPE).
I know, that if I want to show prompt in DialogBox, I have to add "(INITDIA)" before command.
But this command could not have "-" (Why? For example, if you write lisp with "(INITDIA) (command "_-LAYER")", this command will be opened not in DialogBox, but in InteractiveMenu).
But what should I write in lisp to show specified command in InteractiveMenu?
damian,
The underscore "_" before command is for using English version of commands.
The dash "-"  is forcing the command line version of command.
It is not available for all of commands, but if it is available, command will run with out dialog box.
dicra
