System Variable for Crosshair Color
Message 1 of 20
I want to write a lisp for "Change Crosshair's Color to Color number...: ", but I can't find right System Variable.
I know, that CURSORSIZE  is responsible for how long are extended lines of CrossHair.
How to get out of this problem? Please, help.
Replies (19)
Message 2 of 20
hmsilva
Unfortunately, there is no System Variable to change Crosshair Color.
You'll have to set ModelCrosshairColor property at display object.
See this Jeff Mishler's code
Henrique
Message 3 of 20
or, from autodesk help:
(vl-load-com)
(defun c:Example_ModelCrossHairColor()
    ;; This example returns the current setting of
    ;; Model space CrossHairColor. It then changes the value, and
    ;; finally resets the value back to the original setting.
    (setq acadObj (vlax-get-acad-object))
    (setq preferences (vla-get-Preferences acadObj))
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current CrossHairColor value
    (setq currCrossHairColor (vlax-variant-change-type (vla-get-ModelCrosshairColor ACADPref) vlax-vbLong))
    (alert (strcat "The current value for the model space CrossHairColor is " (itoa (vlax-variant-value currCrossHairColor))))
    ;; Change the value for CrossHairColor
    (vla-put-ModelCrosshairColor ACADPref (vlax-make-variant acGreen 19))
    (setq newValue (vlax-variant-change-type (vla-get-ModelCrosshairColor ACADPref) vlax-vbLong))
    (alert (strcat "The new value for CrossHairColor is " (itoa (vlax-variant-value newValue))))
    ;; Reset CrossHairColor to its original value
    (vla-put-ModelCrosshairColor ACADPref (vlax-variant-change-type currCrossHairColor 19))
    (alert (strcat "The CrossHairColor value is reset to " (itoa (vlax-variant-value currCrossHairColor))))
dicra
Message 4 of 20
@dicra: Your code I save as .lsp file and I load it by APPLOAD, but it don't changes Crosshair's color.
Why it dones't work?
@hmsilva:
I wrote lisp using your code
;CCCH = Color CrossHair
(defun c:CCCH
 (set_xhair_clr color)
 (setq color (getint "\nType the value to set CrossHair's color [1/2/3/4/5/6/7]: "))
  set_xhair_clr (color)
; http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/crosshairs-color-system-variable/m-p/1481297#M196118 ; *Jeff Mishler (defun set_xhair_clr (color) (cond ((eq color 1)(setq color 255)) ((eq color 2)(setq color 65535)) ((eq color 3)(setq color 65280)) ((eq color 4)(setq color 16776960)) ((eq color 5)(setq color 16711680)) ((eq color 6)(setq color 16711935)) ((eq color 7)(setq color 16777215)) (t(setq color 1)) ) (vla-put-ModelCrosshairColor (vla-get-display (vla-get-Preferences (vlax-get-acad-object) ) ) color ) ) ;Command: CCCH ; error: too few arguments
 But there is error: too few arguments.
What is bad?
Message 5 of 20
Lee_Mac
What is bad?
You are missing the arguments/variable list for the defun expression, hence set_xhair_clr & color are being interpreted as arguments required by the function.
Perhaps try the following code instead:
(defun c:ccch ( / c )
    (if (setq c (acad_colordlg 7 nil))
        (vla-put-modelcrosshaircolor
            (vla-get-display (vla-get-preferences (vlax-get-acad-object)))
            (LM:ACI->OLE c)
    (princ)
;; ACI -> OLE  -  Lee Mac
;; Args: c - [int] ACI (AutoCAD Colour Index) Colour (1<=c<=255)
(defun LM:ACI->OLE ( c )
    (apply 'LM:RGB->OLE (LM:ACI->RGB c))
;; RGB -> OLE  -  Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->OLE ( r g b )
    (logior (fix r) (lsh (fix g) 8) (lsh (fix b) 16))
;; ACI -> RGB  -  Lee Mac
(defun LM:ACI->RGB ( c / o r )
    (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
        (progn
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                        (vla-put-colorindex o c)
                        (list (vla-get-red o) (vla-get-green o) (vla-get-blue o))
            (vlax-release-object o)
            (if (vl-catch-all-error-p r)
                (prompt (strcat "\nError: " (vl-catch-all-error-message r)))
                r
;; Application Object  -  Lee Mac
;; Returns the VLA Application Object
(defun LM:acapp nil
    (eval (list 'defun 'LM:acapp 'nil (vlax-get-acad-object)))
    (LM:acapp)
(vl-load-com) (princ)
Colour conversion functions are from my site here.
Message 6 of 20
hmsilva
To call Jeff Mishler's code, try
(defun c:CCCH ( / color flag)
  (setq flag t)
  (while flag
    (initget 6)
    (cond ((and (= 'INT (type color))
                (< 0 color 8)
           (setq flag nil)
                (not (< 0 color 8))
           (princ "\nColor value, must be from 1 to 7...")
          ((not color)
           (princ "\nExiting...")
           (setq flag nil)
  (princ)
; http://forums.autodesk.com/t5/visual-lisp-autolisp?-and-general/crosshairs-color-system-variable/m-p/?1481297#M196118
; by Jeff Mishler
(t(setq color 1))
(vla-get-display
color
Henrique
Message 7 of 20
gpcattaneo
Also...
        (setenv "XhairPickboxEtc" (itoa (LM:ACI->OLE c)))
    (princ)
Message 8 of 20
Lee_Mac
gpcattaneo wrote:
Also...
    (princ)
Well found GP - I was looking for that registry key before posting! Smiley Happy
Message 9 of 20
Lee Mac, your lisp is something what I dreamed about. Great respect.
But even more I would like lisp for "Change Color of selected Objects with the DialogBox 'Select Color'".
So it would be something like you just did for the CrossHair, but it would be for Objects.
Soon for a long time I wanted a lisp for it. When I had to change the colour of some Object, I had to go in the Properties Palette (Ctrl+1, remember)
and there I clicked in specified cell and exclusively in this moment I could change its color.
And imagine how much time I wasted this way ... Just because I hadn't possibility to change selected Objects' color with help of DialogBox 'Select Color'.
So here is my request: Could you write such lisp?
Message 10 of 20
Lee_Mac
Thank you damian.
Such a program could quite easily be written, but I see no need for the program -
Why not make a selection of objects & simply use the Object Colour drop-down?
Message 11 of 20
First of all, I don't use Ribbon. I use only MenuBar (I set System Variable called MENUBAR to 1). Just in case I wrote lisp
(DEFUN C:RB  () (COMMAND "_RIBBON"))
(DEFUN C:RBB () (COMMAND "_RIBBONCLOSE"))
 to quickly open and close Ribbon if needed. I don't want to have to have Ribbon opened specially for that Color Tab (what is it called? Color icon?)...
The second thing is, I love to use keyboard. It saves time. I would rather press CRR, Enter to get DialogBox with Color Palette and have this whole Palette befor my eyes than to ride the mouse to the Properties Tab, and go into the cell with the colors, or to this icon which's screen you attached in your last post.
So it depends on who uses AUtoCad. Every man has his own preferences.
Message 12 of 20
So it depends on who uses AutoCad. Every man has his own preferences.
I'm sorry, there was some strange error and in order to pulish my post I clicked once, than second time to the "Post Button" and it is posted two times. But I don't know how to delete one of my messages.
Message 13 of 20
gpcattaneo
  Lee_Mac wrote:
  Well found GP...
Hi Lee, your LM:RGB/ACI/OLE functions are fantastic. Smiley Happy
Message 14 of 20
It is so easy to write lisp for "Change Color of selected Objects via DialogBox"? Not for me 😉
I tried to do it and here is what I did:
; http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/system-variable-for-crosshair-color/td-p/5480926
; On ground of the lisp whichs author is gpcattaneo
; Originally it was CCCH
; CCOBJDIA = Change Color of selected OBJects via DIAlogbox
(defun c:CCOBJDIA ( / c )
;    (if
;;;; Beginnig od part by DW:
        (setq zbior (ssget))
        (command "_CHANGE"
         zbior ""
         "_P"
         "_C"
          c
        ); command
;;;; End of part by DW ;;;;;;
;        (setenv "XhairPickboxEtc" (itoa (LM:ACI->OLE c)))
;    ); if
;; I don't need 'if' (at least I think so)
    (princ)
); defun
But the result is, the Color Palette is opened, I select a Color, but nothing happens.
The CHANGE command  probably is even not loaded...
There are not serious errors, because this lisp is loaded via APPLOAD without error prompts in CommandLine.
What I did wrong and why it doesn't work as I suspected?
Message 15 of 20
I changed appearance of this lisp a little bit and added second lisp. The difference between them is, one uses 'itoa' and the second doesn't.
(defun c:CCOBJDIA
 ( / ClrFromDia ClrAsString)
;    (if
        (setq ClrFromDia (acad_colordlg 7 1))
        (setq ClrAsString (itoa ClrFromDia))
        (command "_CHANGE"
         zbior ""
         "_P"
         "_C"
         ClrFromDia
;         ClrAsString
        ); command
;    ); if
    (princ)
); defun
(defun c:CCOBJDIA2
;    (if
;        (setq ClrAsString (itoa ClrFromDia))
        (command "_CHANGE"
         zbior ""
         "_P"
         "_C"
         ClrFromDia
;         ClrAsString
        ); command
;    ); if
    (princ)
); defun
 I don't understand, why both my lisps don't work... I searched for the lisps with 'acad_colordlg' and I found something interesting.
Here it is. It is a lisp which creates new Layer. The user is asked for entering name for the new Layer, and he chooses new Layer's color via DialogBox!
I proof, it works. And in this lisp there is no 'itoa'.
So what's wrong with my lisps?
Message 16 of 20
gpcattaneo
Try this:
(defun c:CCOBJDIA ( / ClrFromDia zbior)
    (setq ClrFromDia (itoa (acad_colordlg 7 1)))
    (command "_CHANGE" zbior "" "_P" "_C" ClrFromDia "")
    (princ)
Message 17 of 20
It's great, thanks!
But I would like to switch (vahnge) order of the prompts so first will be "Select objects: " and DialogBox with Color Palette will be the second one.
And I don't know how to do it.
Maybe I should use the "while" function?
Message 18 of 20
gpcattaneo
Maybe...
Message 19 of 20
Thank you. I thought about it before I post, but I didn't believe it might be working.
I forgot that before '(setq zbior (ssget))' there is a prompt "Select objects: ".
I thought it will not be prompted.
By the way, gpcattaneo's lisp for "Change CrossHair Color via DialogBox" works very good, so on ground of it I wanted to write lisp for "Change Background Color via DialogBox".
On http://www.afralisp.net/archive/lisp/enviro.htm I found, that the good expression is "Background".
So I thought, that in gpcattaneo's lisp I shoul change "XhairPickboxEtc" to "Background".
And I did so. Here is this lisp:
; Displays ColorPalette, but doesn't apply the chosen color
; to the BackGround color.
; On ground of lisp "Change CrossHair Color via DialogBox" by gpcattaneo
; Originally, there was CCCH
; CCBGGP = Change Color BackGround GPcattaneo
(defun c:CCBGGP ( / c )
        (setenv "Background" (itoa (LM:ACI->OLE c)))
    (princ)
;;;;;;;;;;;;;;;;; by Lee Mac ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;;; http://lee-mac.com/colourconversion.html ;;;;;;;;;;;;;;;
;;;; Colour Conversion Functions              ;;;;;;;;;;;;;;;
        (progn
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                r
(defun LM:acapp nil
    (LM:acapp)
; CCBLGGP = Change Color Layout BackGround GPcattaneo
(defun c:CCLBGGP ( / c )
        (setenv "Layout background" (itoa (LM:ACI->OLE c)))
    (princ)
        (progn
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                r
(defun LM:acapp nil
    (LM:acapp)
; CCLCHGP = Change Color Layout Crosshair GPcattaneo
(defun c:CCLCHGP ( / c )
        (setenv "LayoutXhairPickboxEtc" (itoa (LM:ACI->OLE c)))
    (princ)
        (progn
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                r
(defun LM:acapp nil
    (LM:acapp)
But it doesn't work.
Can you tell me why?
Generally, I will be write such lisp for "Layout background", "XhairPickboxEtc", too.
Message 20 of 20
Lee_Mac
gpcattaneo wrote:
Lee_Mac wrote
  Well found GP...
Thanks GP! Smiley Happy
