Bind the dwgs
Bind the dwgs
Message 1 of 8
Bind the dwgs
Hi...Dear members
Can anybody please help me to make a lisp for eTransmit to bind the dwgs,
currently am using this by manually if i get a lisp file for this i can call the lisp via autoscript
my requirements are
*eTransmit setup name - STANDARD,
*binded dwgs need to save separate folder (folder name)  - C /  DWG
*binded dwgs name and folder name should be the same as original dwgs name and folder ( my original dwg are in separate folders like .. ELECTRICAL ,   STRUCTURAL, ARCHITECTURAL etc...)
*and transmittal package type ( folder set of files) not zip file
am attaching an image of my transmittal setup page
Replies (7)
Message 2 of 8
hmsilva
Hi tdkhtr,
using 'etransmit' command via AutoLISP, we can not do much more than use the command line version.
If your settings are stored at the 'Standard' setup, perhaps something like this
(command "_.-ETRANSMIT" "_CH" "Standard" "_C")
Henrique
Message 3 of 8
Hi Hmsilva
Thanks for ur reply
yes this is OK for me
but how can avoid PlotCfgs folder
when am doing with more than one dwg
1st file is ok then 2 nd file it is asking
for Overwrite file
so i change the code
(command "_qsave" "_.-ETRANSMIT" "_CH" "Standard" "_C" "_all")
now the problem for 1st file (bcoz when "_all" command is running it is stuck on there )
so am looking for avoid PlotCfgs folder
Message 4 of 8
hmsilva
You're welcome, tdkhtr.
Untested...
(defun c:demo ()
  (command "_qsave" "_.-ETRANSMIT" "_CH" "Standard" "_C")
  (while (> (getvar 'cmdactive) 0)
  (command "_All")
  (princ)
Henrique
Message 5 of 8
Dear Hmsilva...
Thanks a lot...
This is what i really need..
Thanks...
Message 6 of 8
hmsilva
Glad I could help
Henrique
Message 7 of 8
Hi...
When i run this lisp sometime error message displaying (shown below)
Command: demo
_qsave
Command: _.-ETRANSMIT
Updating fields...
Enter an option [Create transmittal package/Report only/CUrrent setup/CHoose
setup] <Report only>: _CH
Choose Transmittal Setup or [?] <Standard>:Standard Enter an option [Create
transmittal package/Report only/CUrrent setup/CHoose setup] <Report only>: _C
Gathering files ...
Transmittal created: C:\DWG.
Command: _All Unknown command "ALL". Press F1 for help.
looking any help to solve this
Thanks..
Message 8 of 8
hmsilva
@Anonymous wrote:
Command: demo
_qsave
Updating fields...
Gathering files ...
Hi tdkhtr,
unfortunately I can't reproduce this behavior running the code...
Henrique
