What is the system variable for displaying scroll bar in drawing?
dbroad
Not everything is controlled by system variables.
For this aspect, you need to access the display preferences.  Look at the ActiveX  Object Model (ActiveX) http://help.autodesk.com/cloudhelp/2016/ENU/AutoCAD-ActiveX/files/GUID-A809CD71-4655-44E2-B674-1FE20...
There are helper functions to work with the activex object properties and methods.  These will gain control over many parts of AutoCAD
For example:
(setq displaypref
		   (vla-get-display
		     (vla-get-preferences
		       (vlax-get-acad-object))))
(vla-get-displayscrollbars displaypref)
(vla-put-displayscrollbars displaypref :vlax-true)
;Alternatively you can use :vlax-false to turn them off.
Architect, Registered NC, VA, SC, & GA.
I've found the solution with your help 🙂
AcadPreferences Preferences = (AcadPreferences)Autodesk.AutoCAD.ApplicationServices.Application.Preferences;
Preferences.Display.DisplayScrollBars = false;
Do you know why I'm getting an error when I want to set Taskbar = 0;
Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable("TASKBAR", 0);
"An exception of type 'Autodesk.AutoCAD.Runtime.Exception' occurred in accoremgd.dll but was not handled in user code"
dbroad
Please note: This is a visual lisp newsgroup.  When you ask a question without specifying the customization language, you will get Visual Lisp as a response.  There is a VBA newsgroup that you can post VBA questions on.  I do not have the visual basic plug-in for AutoCAD at my current location so cannot answer your question.  If it remains unanswered tonight, I will let you know.
dbroad
This code works. Your code snippet looked a bit weird unless I am mistaken about it being VBA. If you need .NET code, visit the .NET newsgroup.  Hope this helps.
Option Explicit
Sub nobars()
Dim dpref As AcadPreferencesDisplay
Set dpref = Application.Preferences.Display
dpref.DisplayScrollBars = False
End Sub
Sub bars()
dpref.DisplayScrollBars = True
End Sub
@dbroad
Thank you very much for help. I've made a mistake and choose wrong category 🙂
In case of TASKBAR - this is not system variable, just want to write if something will search for it.
Smiley Happy
dbroad
OK, glad to help.
Taskbar is not a system variable.  It is a command.  It should not have any relevance however in Window 8 or higher and should not have any relevance in the CORE console because that is a background process that would not have a taskbar presence anyway.  The core console if a non-interactive environment for creating/editing drawings.
