Lisp to set the fonts search path
jbear0000
Message 1 of 14
jbear0000
I have the following code that was created by Bigal and I modified to meet my needs, but I can't figure out how to set the fonts folder. I want to remove this: C:\Program Files\Autodesk\AutoCAD 2016\Fonts and replace it with Y:\Library\CAD Support Files\Fonts
The original code is here:
http://www.cadtutor.net/forum/archive/index.php/t-77358.html?s=7273bed22b69b0b962a29ed2e9740df1
This is what I have:
; resets the paths usefull for update versions of Autocad
; by BIGAL 2011
; This sets a reference to the install path of your product
; the gets are their for info maybe other use
; use this to find other settings
;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T)
(vl-load-com)
; make temp directory
(vl-mkdir "c:\\Autocad Autosaves")
(setq *files* (vla-get-files (vla-get-preferences (vlax-get-Acad-object))))
; Autosave Location
(vla-put-AutoSavepath *files* "C:\\Autocad Autosaves")
; Printers Configuration Search Path
(vla-put-PrinterConfigPath *files* "Y:\\Library\\Plotters")
; Printer Description File Search Path
(vla-put-PrinterDescPath *files* "Y:\\Library\\Plotters")
; Plot Style Table Search Path
(vla-put-PrinterStyleSheetPath *files* "Y:\\Library\\CAD Support Files\\Plot styles")
; Drawing Template File Location
(vla-put-TemplateDwgPath *files* "Y:\\Library\\CAD Support Files\\Template Files")
; Default Template File Name for QNEW
(vla-put-QnewTemplateFile *files* "")
;make new support paths exist + new
(setq paths (vla-get-SupportPath *files*))
(setq coggpaths
Y:\\Library\\CAD Support Files\\Fonts;
; Plot Log File Path
(vla-put-PlotLogFilePath *files* "C:\\Autocad Autosaves")
; Log File Path
(vla-put-LogFilePath *files* "C:\\Autocad Autosaves")
; end use of *files*
(vlax-release-object *files*)
; exit quitely
(princ "All Done")
Replies (13)
Message 2 of 14
hmsilva
Hi jbear0000,
we should not remove the default SupportPath.
BIGAL's approach, is correct, adding the new search paths first, AutoCAD will find the new directories, and if there exist some network problem will find the default ones...
So, try to put back in the code this two code lines
(setq newpath (strcat coggpaths paths))
(vla-put-SupportPath *files* newpath)
Hope this helps,
Henrique
Message 3 of 14
jbear0000
Thank you hmsilva, I didn't realize that those lines of code were part of that section for the support files.
What is I wanted to have it look in more than one folder for plot styles? How could I make it do that?
Message 4 of 14
hmsilva
You're welcome, jbear0000
To add a new plot style folder, maybe something to do the trick:
(setq PSSP (vla-get-printerstylesheetpath *files*))
(vla-put-PrinterStyleSheetPath *files* (strcat "Y:\\Library\\CAD Support Files\\Plot styles;" PSSP))
Hope this helps,
Henrique
Message 5 of 14
jbear0000
That works, but I am adding this code to a lisp that will run every time cad starts and it causes duplicate paths. How can I have it just delete the paths for the plot styles and then just replace them with the ones listed in the coding?
Message 6 of 14
hmsilva
(if (not (wcmatch PSSP "*Y:\\Library\\CAD Support Files\\Plot styles*"))
Henrique
Message 7 of 14
jbear0000
Thanks again, I was able to get that to do exactly what I wanted.
Message 8 of 14
hmsilva
Henrique
Message 9 of 14
jbear0000
How would I get it to be flexible for any username to replace
C:\Users\%username%\AppData\Roaming\Autodesk\C3D 2016\enu\plotters\Plot Styles
with
Y:\Library\CAD Support Files\Archive\Plot styles?
(if (wcmatch PSSP "*C:\\Users\\%username%\\AppData\\Roaming\\Autodesk\\C3D 2016\\enu\\plotters\\Plot Styles*")
  (vla-put-PrinterStyleSheetPath *files* (strcat "Y:\\Library\\CAD Support Files\Archive\\Plot styles;" PSSP))
But apparently %username% isn't the right way to go about it. I found (getenv "username"), but am not sure how to use it in something like this.
Message 10 of 14
hmsilva
(wcmatch PSSP (strcat "*C:\\Users\\" (getenv "username") "\\AppData\\Roaming\\Autodesk\\C3D 2016\\enu\\plotters\\Plot Styles*"))
Henrique
Message 11 of 14
jbear0000
Thanks again, that works to add the new folder, but how can I get it to then remove the C:\\Users\\" (getenv "username") "\\AppData\\Roaming\\Autodesk\\C3D 2016\\enu\\plotters\\Plot Styles folder?
Message 12 of 14
hmsilva
(if (wcmatch PSSP (strcat "*C:\\Users\\" (getenv "username") "\\AppData\\Roaming\\Autodesk\\C3D 2016\\enu\\plotters\\Plot Styles*"))
  (vla-put-PrinterStyleSheetPath *files* "Y:\\Library\\CAD Support Files\Archive\\Plot styles")
Hope this helps,
Henrique
Message 13 of 14
jbear0000
That did it, thanks again for all of your help.
Message 14 of 14
hmsilva
Glad I could help
Henrique
