Replace all texts strings
msarqui
Message 1 of 16
msarqui
Hello guys,
It would be possible to have a routine to replace the strings of multiple texts/mtexts by another string?
If possible with a SSGET to have multiple selection.
The routine would have to consider that the selected texts can contain different strings.
The routine will automatically change every string of selected texts by, for exemple "XXX"
Exemple:
The text "SITE PLAN" will became "XXX"
The text "ELEVATIONS" will became "XXX"
and so on...
Thanks for your help!
Marcelo
Replies (15)
Message 2 of 16
hmsilva
Hi Marcelo,
perhaps something like this:
(defun c:demo (/ replace_ newpath path paths ss)
   (defun replace_ (sset pattern newpattern / ent i str)
      (repeat (setq i (sslength sset))
         (setq ent (entget (ssname sset (setq i (1- i))))
               str (cdr (assoc 1 ent))
         (if (wcmatch str (strcat "*" pattern "*"))
            (progn
               (while (wcmatch str (strcat "*" pattern "*"))
                  (setq str (vl-string-subst newpattern pattern str))
               (entmod (subst (cons 1 str) (assoc 1 ent) ent))
   (if (setq paths   '("SITE PLAN" "ELEVATIONS")
             newpath "XXX"
             ss      (ssget "_:L" '((0 . "TEXT,MTEXT")))
      (foreach path paths
         (replace_ ss path newpath)
   (princ)
Hope this helps,
Henrique
Message 3 of 16
paullimapa
Is there a reason for not using the built-in AutoCAD "FIND" command?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 4 of 16
msarqui
Hello Henrique
Sorry my poor English. I do not explained myself well.
What I mean is, all texts, no matter what kind of string it contains, will be replaced by "XXXX".
The "SITE PLAN" and "ELEVATIONS" were examples only, to show that the text can contain one word, two words, and so on...
So, the text can contain any type of strings.
And that is the reason to not use FIND command.
Marcelo
Message 5 of 16
paullimapa
That's why I mentioned AutoCAD's built-in FIND command.
You just have to click on the down arrow (see attached image) and check the option "Use wildcards".
Then under "Find what" enter asterisk *
Under "Replace with" enter something like ALL
And it'll replace all text strings with ALL
Paul Li
IT Specialist
@The Office
Message 6 of 16
msarqui
Hi pli.
If I could, I would edit my last reply to add this: "It must be in a selection set.
Thansk
Message 7 of 16
paullimapa
Yep, that feature is available to with AutoCAD's built-in FIND command under "Find where" (see attached screen capture)
Paul Li
IT Specialist
@The Office
Message 8 of 16
hmsilva
@msarqui wrote:
Hello Henrique
Marcelo
Hi Marcelo,
quickly revised code...
(defun c:demo (/ replace_ newpath path ss)
                (progn
    (if (and (setq path (getstring T "\nEnter text to replace: "))
             (/= path "")
             (setq newpath (getstring T "\nEnter text to replace with: "))
             (/= newpath "")
             (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
    (princ)
Hope this helps,
Henrique
Message 9 of 16
Kent1Cooper
For all-Text selection, you can just do it in the Properties box, putting your XXX or whatever you want in the Content slot in the Text category.  But you can't do multiple Mtext that easily [if you try, it wants you to edit the content of each object separately].  For an either-or-both-types selection, here's one way:
(defun C:TXXX (/ ss n); = Text content to "XXX"
  (vl-load-com); if needed
  (prompt "\nTo change content of ALL selected Text/Mtext to \"XXX\",")
  (if (setq ss (ssget "_:L" '((0 . "*TEXT"))))
    (repeat (setq n (sslength ss))
      (vla-put-TextString (vlax-ename->vla-object (ssname ss (setq n (1- n)))) "XXX")
    ); repeat
  ); if
); defun
It could, of course, be made to ask the User for the content they want all such objects to have, if XXX isn't always what you want.
Kent Cooper, AIA
Message 10 of 16
msarqui
That is perfect Kent. Thanks a lot!
Henrique, thanks for try, but Kent got exactly what I would like to have.
Pli, I really needed this on lisp. Kudos for you because I did not know about the wild cards in the find command.
Thanks all.
Marcelo
Message 11 of 16
hmsilva
Marcelo,
your goal was just select text/mtext objects and put a text string "XXX" in selected text objects???? 🙂
I'm glad you found a solution!
Henrique
Message 12 of 16
msarqui
@hmsilva wrote:
 Marcelo,
Yes Henrique, just that.
As you know, english is not my strongest ability... 🙂
Message 13 of 16
hmsilva
@msarqui wrote:
@hmsilva wrote:
 Marcelo,
Cheers
Henrique
Message 14 of 16
How would you modify this so that you can preload in some options? Like say you input "x" and you get 'xxxx', or you input 'email' and the lisp returns 'toohottohoot@blahinc.com'?
Message 15 of 16
Sea-Haven
You would need a list of options, and the text needs a check does search text exist if yes replace should it be just total replace or a word ?
(("x" "XXXX")("mail" "alanh.com.au"))
Do a google pretty sure this exists letting you do multiple replace. Maybe Lee-mac.com
Message 16 of 16
pbejse
I you wanted to be prompted for what is and what will at every call to the command, might as well stick with Find and Replace.
Otherwise, use an external text file as the source. If the values are constant then go with hard-coding the string values.
