@Anonymous wrote:
Can you post a DWG for this? so we know the format of the exploded dimension.
That hardly seems necessary. Explode one and you'll know -- some Lines [and/or Arcs from angular Dimensions], an Mtext entity from the text content, Blocks from the arrowheads [or Solids from the default closed-filled type]. I also find that the definition points on the DEFPOINTS Layer don't become Point entities when I Explode a Dimension, but simply disappear, which would make it all the more impossible for a routine to be able to accurately reconstruct the Dimension from which those other parts may have come [but one thing I don't know is whether those survive the transition through DXF format if the Dimensions were "whole" in the source drawing].
Even if one could imagine selecting exactly the right set of parts to put back together into one Dimension entity, and a routine being able to evaluate things about them [such as determining which two Lines are parallel (and also "aim" at the definition Points if those are present) that were the extension lines, or whether two Arcs are concentric and two Lines are radial from their common center, and whether two Blocks or Solids relate appropriately to the presumed extension lines, and so on], there are so many potential complications:
:: All sorts of parts of Dimensions can be suppressed, so there might not be two extension lines, or two arrowheads, or ...;
:: Arrows and/or text can be inside or outside extension lines or some of each, and text could be out-of-line anywhere at the end of a leader-connector;
:: If it can determine the distance between two parallel Lines and assume they were the extension lines, but the Mtext content doesn't match the distance between them, the difference might be a result of the rounding-off value or that the text content was explicitly overridden;
:: If the text contains more than just linear/angular values, there would be no way to determine whether that was an override or a prefix or suffix built into the Dimension Style definition;
:: There would be no way to determine from the pieces the difference between a Dimension that was drawn with the more generic DIMLINEAR from one that was drawn with the more specific DIMHORIZONTAL or DIMVERTICAL, or with DIMROTATED, or with DIMALIGNED even if the extension lines are the same length and not orthogonal [e.g. it could have been DIMLINEAR under a different UCS], but the difference could be important [i.e. it would affect how it would be changed if you later Stretched something];
:: If the definition points are not there, there would be no way to determine where they would have been in relation to the ends of extension lines, because that would have been determined by the extension-line offset variable value for the Dimension Style it was drawn with, but the pieces won't carry any information about that;
:: There could be different numbers of dimension lines/arcs depending on the text-location settings of the Style;
:: I'm sure I could come up with some more if I thought about it further....
It seems to me that in order to reliably "get it right," a routine to do this would need to ask the User for enough specifics in selections, and with enough qualifications, that it would not be any less work than just Erasing those pieces and drawing the Dimension anew.
Kent Cooper, AIA
