Set VP Linenweight in LSP
eamon.fleming
Message 1 of 16
eamon.fleming
Hi guys I have been cobbling together a program to set lineweight to colors automatically so I can update hundreds of prototypes.
What I have so far is working fine for the lineweight but I was wondering if it is possible to set VP lineweights at the same time using a similar method
(defun c:assignlineweights ( / layers_col col)
 (SETVAR "lwunits" 1 )
  (vl-load-com)
  (or *acaddoc* (setq *acaddoc* (vla-get-activedocument (vlax-get-acad-object))))
  (setq layers_col (vla-get-layers *acaddoc*))
  (vlax-for item layers_col
    (setq col (vlax-get-property item 'color))
    (cond ((= col 1)(vlax-put-property item 'LineWeight acLnWt025))
             ((= col 2)(vlax-put-property item 'LineWeight acLnWt120))
             ((= col 3)(vlax-put-property item 'LineWeight acLnWt035));copy down and change to suit
  (SETVAR "lwunits" 0 )
  (PRINC "Assign Lineweights to Layers loaded.  Type assignlineweights to run.")
(princ)
I can't seem to find a variable or property like acLnWt  but for VP Lineweight
Thanks to he guys whose code I poached already
Any help would be greatly appriciated
Eamon
Replies (15)
Message 2 of 16
wispoxy
@eamon.fleming Intergrate this code into your current lisp. It should prompt you for a lineweight and has a high rating, make sure to preset the vp on its own layer or other lines will be effected also.
I got the code from Lee Mac Forums, its creator is unknown. The code is really for lines by layer.
(defun c:LWChange ( / lws lw n )
(setq lws
'(-3.00 0.00 0.05 0.09 0.13 0.15 0.18 0.20 0.25 0.30 0.35 0.40 0.50
0.53 0.60 0.70 0.80 0.90 1.00 1.06 1.20 1.40 1.58 2.00 2.11
(while
(and
(setq lw (getreal "\nSpecify Lineweight (-3 for Default): "))
(not (member lw lws))
(princ "\n--> Invalid Lineweight.")
(if lw
(progn
(setq lw (if (<= 0 lw) (fix (* 100 lw)) (fix lw)))
(vlax-for l (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(if
(and
(wcmatch (setq n (strcase (vla-get-name l))) "*FURN*,*EQPM*,*PFIX*")
(not (wcmatch n "MV-*EQPM*"))
(vla-put-lineweight l lw)
(princ)
(vl-load-com) (princ)
Message 3 of 16
eamon.fleming
Thanks Andrew I will check this out this afternoon
Eamon
Message 4 of 16
eamon.fleming
Hi Andrew I looked at the code & gave it a test run & I am not sure what it does?
I am trying to set the VP Lineweight of layers based on the color of the layer, see the image below
if the Lineweight is 0.70mm I want to set the VP Lineweight to 0.35mm (1/2 scale)
The code I have works for the lineweight but I don't know the variable for VP lineweight 😞
I have given up on the help in autocad as you can't browse any more, you pretty much need to know what you want to search for.
Thanks in advance
Eamon
Message 5 of 16
hmsilva
  (vl-load-com)
(princ)
Eamon
Hi Eamon,
there is no property for VPLineweight...
Lineweight in a viewport( and all overrides properties except layer visibility overrides)  is stored as dictionary data in layer extension dictionarie, and the Xrecord name is ADSK_XREC_LAYER_LINEWT_OVR
If you are not familiar with dictionaries, probably it will be easier, to set current each viewport and use the -vplayer command...
Hope this helps,
Henrique
Message 6 of 16
eamon.fleming
Thanks Henrique, I know nothing about dictionaries so I will look into the vplayer command
Eamon
Message 7 of 16
hmsilva
Eamon
You're welcome, Eamon!
As a starting point, a quick and dirty 'demo'...
(defun c:demo (/ ctab ent lay lst lw name)
    (while (setq lay (tblnext "LAYER" (null lay)))
        (setq name (cdr (assoc 2 lay))
              ent  (entget (tblobjname "LAYER" name))
              lw   (cdr (assoc 370 ent))
        (if (> lw 0.0)
            (progn
                (setq lw (/ lw 200.0))
                (if (assoc lw lst)
                    (setq lst (subst (cons lw (strcat (cdr (assoc lw lst)) "," name)) (assoc lw lst) lst))
                    (setq lst (cons (cons lw name) lst))
                (setq ctab (getvar 'ctab))
                (foreach layt (layoutlist)
                    (setvar 'ctab layt)
                    (command "vplayer")
                    (foreach x lst
                        (command "LW" (car x) (cdr x) "_All")
                    (command "")
                (setvar 'ctab ctab)
    (princ)
Hope this helps,
Henrique
Message 8 of 16
eamon.fleming
Thanks Henrique I will look at this tomorrow & see how I make out
Eamon
Message 9 of 16
wispoxy
@eamon.fleming Glad to see your problem was resolved.
@hmsilva Well done!
Message 10 of 16
hmsilva
@Anonymous wrote:
@hmsilva Well done!
Thank you, wisp!
Henrique
Message 11 of 16
eamon.fleming
Hi Hernrique I finally got some time to play with this demo & seems to be setting the VP lineweights but it sets the first layer/color to 0.024" then all the rest to 0.083" ? I am having trouble deciphering the code to see where the 0.083" is being set? is it the LW variable?
Thanks in advance
Eamon
Message 12 of 16
hmsilva
Thanks in advance
Eamon
Hi Eamon,
I do not have AutoCAD in this laptop, if possible, post a sample dwg, and tonight I'll see what I can do...
Henrique
Message 13 of 16
eamon.fleming
Hi Henrique thanks for the fast responce. I have attached a simple sample drawing that I ran my program on to set the lineweights per color thenI ran demo to set the VPlineweight
This drawing is typical of most of our templates in that the model space viewport in the layout is scaled to 1:2
In a perfect world I would like demo to see what the lineweight is per layer then divide it by 2 to set the VPlineweight
Eamon
Message 14 of 16
hmsilva
Eamon,
tested in a borrowed  PC, without error....
Henrique
Message 15 of 16
eamon.fleming
Hi Henrique that is great, I notice that the lineweights are in mm, is that the problem with mine that I have them set to inches?
OK I just set the lineweight units to mm & it works! thanks Henrique
Eamon
Message 16 of 16
hmsilva
Eamon
Eamon,
sorry, but feet and inches are not my world, I'm a metric guy.
Glad I could help!
Henrique
