What is "Ecount"
What is "Ecount"
Message 1 of 8
What is "Ecount"
Good Day Everyone!
I am just starting with AutoLISP, I've seen a few sample codes and I am curious
about the function ecount.
Like what is it for? Is it even a function, idk.
Beginner here.
I hope anyone can answer.
Thankss
Replies (7)
Message 2 of 8
ВeekeeCZ
You should post the code where you got it from.
Anyway, very likely it's just a variable name for a counter (as index number). As in THIS  case, or  THIS  case.
Help HERE uses the word index for the same.
Lee HERE  uses i (as index) for the same purpose.
I am using i. Some of us use n
Message 3 of 8
john.uhden
Yep.  I always use i as an abbreviation for index.  I'm a lousy typist, so the fewer characters the better.  For keeping score I will use n, n1, n2, and maybe even n3.
You may often see me use (setq 2pi (* pi 2)) because if I need the value more than once there is less to type.  It's easier to read as well.
John F. Uhden
Message 4 of 8
Kent1Cooper
@Anonymous wrote:
... I am curious about the function ecount.
[You can determine whether something is an AutoLisp Function in the Functions Reference in Help, >here<.]
Kent Cooper, AIA
Message 5 of 8
john.uhden
@Kent1Cooper  just jogged my brain.
If ecount is a symbol for anything, and it is global, then enter the following at the Command prompt and see what it returns...
(type ecount) <-| Enter
Otherwise, please post your code and we will figure it out.
Don't fret.  Your question is good.  That's how you learn.
Uhden motto #1:  "You gotta start somewhere."
Uhden motto #2:  "If you don't know, ask."
Uhden motto #3:  "You just can't deal with an @$$hole."
Uhden motto #4a:  "You don't make yourself bigger by belittling others."
Uhden motto #4b:  "You don't get any cleaner by dragging others into the dirt with you."
John F. Uhden
Message 6 of 8
Sea-Haven
Dont forget these also use same idea often for a package would put in master library like rtd dtr.
(setq pi2 (/ pi 2.)
pi45 (* pi 0.25)
pi135 (* pi 0.75)
and so on
Message 7 of 8
Thank you for the response, it seems it was just a variable.
Sorry for the ignorant question, I have practically zero knowledge on basic functions at the time of posting.
But now I'm learning bit by bit.
Message 8 of 8
Thank you Kent1Cooper, I usually neglect help documentations.
But the documentation for LISP sure is helpful.
Many Thankss!
