Copy Layout to Multiple Drawings at Once
I have a project with around 300+ drawings. I need to apply a layout to all of them for printing, how is this possible? I can't believe that i'd have to do this will all 300 drawings manually? or drag and dropping with design center?? I've looked all over with no solution. If this is the case I'll never use this software again.
ronjonp
Look into sheet set manager ( or Publish ) and use a defined page setup if I'm understanding the question correctly.
devitg
@Anonymous , maybe it can be do by ODBX . ObjectDataBaseExchange
Please upload a few fake.dwg , as not to infringe confidentiality, and the basic also-fake.dwg, as to copy the source layout to all .
Sea-Haven
Can you provide some more details are you meaning to have a layout with a company title block and then somehow create a model view at scale? The title block easy done 300 dwgs various methods probably aeccoreconsole is best.
Making or select a layout like layout1 then just insert or xref title block.
