Weld.lsp loaded but nothing happens
mohezz2
Observer Observer
Message 1 of 8
mohezz2
Observer
Observer
Hello All,
I loaded the weld.lsp from Chris Crain and added the weld.dcl and welds.slb at the support file locations.
When I type "weld", nothing happens, no errors.
The file is attached. I am using Autocad 2025
Ideas?
Replies (7)
Message 2 of 8
imadHabash
  • You may need to put the 3 files (WELD.lsp, WELD.dcl & WELD.slb) in the same support folder. then restart AutoCAD.
  • I cannot unzip your previous attached .zip file!!!
Imad Habash
Message 3 of 8
cadffm
The same folder or not, doesn't matter.
Zip file works well, is extractable.
Issue: Is very special, the code works by direct evaluation, but not by running via commandname or (c:weld)
The part in question checks for .dcl and start a dialog - like  (if dclexist (rundialog) (otherwiseAlert))
Thread is for Lisp-Board
Sebastian
Message 4 of 8
mohezz2
Observer
Observer
Thanks for your reply. @imadHabash @cadffm ,
I tried to debug the code, it looks like it was trying to set the CLAYER variable to "welds", but there was no "welds" layer in the file, so once I created the layer the lsp worked well. This is weird for me as I expected the lsp to maybe draw in the current layer anyways.
I wonder if there are updated versions of the lsp?
I got the lsp from a forum (not cadalyst , since I cannot find it there anymore).
Do you know where I can find it in cadalyst ? or any other forum ?
Message 5 of 8
imadHabash
You may contact Cadalyst support. They may still have an archive of the “CAD Tips” code repository and could help you locate or retrieve the file.
Imad Habash
Message 6 of 8
Kent1Cooper
@imadHabash wrote:
You may contact Cadalyst support. They may still have an archive of the “CAD Tips” code repository ....
[Their Hot Tip Harry page has a Resources pull-down which includes an item called "CAD Tips LISP Archive," but it does not take you to any such thing.  I have written to point this out to them, since I have a lot of routines there that I sometimes want to refer people to, but so far....  Maybe if a lot of people do the same, something will happen.]
Kent Cooper, AIA
Message 7 of 8
pendean
Community Legend
Community Legend
@mohezz2 wrote:
...there was no "welds" layer in the file, so once I created the layer the lsp worked well. This is weird for me as I expected the lsp to maybe draw in the current layer anyways. ...
Since it does not, why not preload that required-layer in your files in your templates or with a script or use ActionRecoder or a startup or... ? while you wait... .
Message 8 of 8
komondormrex
just add command to create a "welds" layer, like in the attached, lines 1756-57.
