Wall Calculate
Wall Calculate
k005
Advisor Advisor
Message 1 of 24
Wall Calculate
k005
Hello there
How can I calculate the X distance from the P1 and P2 points as I have specified in the appendix, and multiply the result with the Height, and print the result in the middle of the wall in m² when measuring the walls of 10?
We can't drop the gaps.
0- Wall width : ? ( 10 )
1- first point, second point
2- wall height : ?
X (cm) * Wall height (cm)
and the command will continue without ending after typing the text...
Result :   10 luk Duvar : xxx m²
Replies (23)
Message 21 of 24
hak_vz
@Sea-Haven wrote:
Hak_vz did you have a look at the image I posted, takes into account stacked walls ie window opening. The windows have a bottom line and a top line both with "Thickness".
OP was looking for something completely different, and openings were not of his concern i.e what he needs is horizontal and vertical component from two points. Normally we would count all openings and using "thickness" is good idea to store wall height. For simplicity, calculations for wall areas are usually made with assumption that walls have no openings.
Miljenko Hatlak
Message 22 of 24
Sea-Haven
Understand when you cut a brick in half need a % increase to make up for this. With bricklaying machines I am sure they have some smart algorthims for how many bricks required, the most up to date now is 3D cement printing wall machines.
Youtube robot bricklayer video.
Message 23 of 24
k005
@Kent1Cooper
I opened a new topic for this. However, it may be much easier to change it from here. which I was going to try to add here.
After selecting pt1 and pt2, how can we perform a solid scan at the end of the procedure? ?
Note: scan color must be white. Otherwise, the text will not appear...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/point1-and-point2-to-hatch/td-p/1223...
Message 24 of 24
k005
