Point1 and Point2 to Hatch
k005
Advisor Advisor
Message 1 of 29
k005
Hello everyone
As I mentioned in the attachment, how can I have a solid scan automatically when I mark pt1 and pt2?
The place where I operate is a closed area...
Thanks.
Replies (28)
Message 2 of 29
Sea-Haven
-Hatch mp etc the point is the midpoint of pt1 pt2.
(setq mp (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5)))
Message 3 of 29
k005
well okay. But how should the rest of the code be?
Message 4 of 29
Sea-Haven
Don't you know how to do getpoint and -hatch ?
You have asked for lots of stuff should be learning by now.
Message 5 of 29
calderg1000
Regards @k005
Here you have two options to select the interior point, requested by the Hatch command. Although I think there must be a simpler way to do it.
;;;___
(defun c:hh1 (/ p1 p2 pm)
  (setq p1 (getpoint "\nPick Point 1: ")
        p2 (getpoint p1 "\nPick Point 2: ")
        pm (mapcar '(lambda (x y) (/ (+ x y) 2.)) p1 p2)
  (command "_-hatch" "p" "s" pm "")
;;;___
(defun c:hh2 (/ p1 p2 pm)
  (command "_line" "_non" p1 "_non" p2 "")
  (setq pm
         (vlax-curve-getpointatparam (vlax-ename->vla-object (entlast)) 0.5)
  (entdel (entlast))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 6 of 29
k005
Hi @calderg1000
I tried hh1 and it worked. hh2 did not work. There is only one problem. I show it in the attachment. It doesn't scan the whole thing... just the middle part.
It needs to scan all of them.
Message 7 of 29
ronjonp
@k005
Why would you want to pick two points when natively you can pick one to hatch?
Message 8 of 29
k005
Because this isn't just a scan... this is the completion of a function. additional code.
It will be added to the function here...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/wall-calculate/td-p/10499229
Message 9 of 29
CADaSchtroumpf
For basic use you could use this.
This does not create hatching, but a solid which will turn out to be less demanding in definition.
(defun c:foo ( / p1 p2 p3 p4)
  (initget 9)
  (setq p1 (trans (getpoint "\nFirstpoint: ") 1 0))
  (initget 41)
  (setq
    p4 (trans (getcorner (trans p1 0 1) "\Second point: ") 1 0)
    p2 (list (car p1) (cadr p4))
    p3 (list (car p4) (cadr p1))
  (entmake
    (append
      (list
        '(0 . "SOLID")
        '(100 . "AcDbEntity")
        (cons 410 (getvar "CTAB"))
        (cons 8 (getvar "CLAYER"))
        '(100 . "AcDbTrace")
        (cons 10 p1)
        (cons 11 p2)
        (cons 12 p3)
        (cons 13 p4)
        (cons 39 (getvar "ELEVATION"))
  (prin1)
Message 10 of 29
k005
Yes . this worked. Thank you. However, I cannot integrate this code into my Wall account. It seems a bit complicated to me.
My goal was to add this to the function here.
That is, scanning after pt1 and pt2 and printing the m² information. Currently only m² information is written... I should add scanning to it. and text should appear...
Message 11 of 29
CADaSchtroumpf
This?
(defun c:foo ( / p1 p2 p3 p4 ang wh l luk text)
  (initget 9)
  (setq p1 (trans (getpoint "\nFirst point: ") 1 0))
  (initget 41)
  (setq
    p4 (trans (getcorner (trans p1 0 1) "\nSecond point: ") 1 0)
  (if (> (distance p1 p3) (distance p1 p2))
    (setq ang 0.0)
    (setq ang (* 0.5 pi))
  (initget 7)
  (setq
    wh (getreal "\nWall height >")
    l (distance p1 p4)
    luk (min (distance p1 p3) (distance p1 p2))
    text (strcat (rtos luk 2 0) " luk Duvar : " (rtos (* l wh 1E-04) 2 2)  " m\U+00B2")
  (entmake
    (list
      '(0 . "SOLID")
      (cons 10 p1)
      (cons 11 p2)
      (cons 12 p3)
      (cons 13 p4)
  (entmake
    (list
      '(0 . "TEXT")
      '(100 . "AcDbText")
      '(62 . 250)
      '(10 0.0 0.0 0.0)
      (cons 40 luk)
      (cons 1 text)
      (cons 50 ang)
      '(71 . 0)
      '(72 . 1)
      (cons
        11
        (list
          (* (+ (car p1) (car p4)) 0.5)
          (* (+ (cadr p1) (cadr p4)) 0.5)
          (* (+ (caddr p1) (caddr p4)) 0.5)
      '(73 . 2)
  (prin1)
Message 12 of 29
k005
Thank you very much. , thank you for your efforts. @CADaSchtroumpf
Can we add these parts as well?
It will be more useful if it loops and remembers the wall height.
Message 13 of 29
ВeekeeCZ
Draw a rectangle, hatch it, and remove the rectangle. Or keep it if you don't mind it.
It's just a simple macro... how difficult to write it it could be... gees.
(defun c:RecHatch (/ e)
  (command "_.rectang" pause pause)
  (setq e (entlast))
  (command "_bhatch" "_s" e "" ""
	   "_.erase" e "")
  (princ)
Message 14 of 29
k005
Why should I draw rectangle? Is there such a thing as drawing a rectangle for the purpose? Have you seen something like this?
Message 15 of 29
ВeekeeCZ
You are looking for the simplest and reasonably efficient way to automate a task. And if this means simply drawing a helper object, then that's a legitimate way to solve the issue.
Message 16 of 29
Kent1Cooper
If these are always and only orthogonally-oriented rectangular areas, I would suggest using the draW boundary option in the -HATCH command.  It can pull the coordinates from the two points to define corners, and there will be no object drawn that needs to be deleted.  In simplest terms, and lightly tested:
(defun C:HRS (/ p1 p2); = Hatch Rectangle Solid
  (setq
    p1 (getpoint "\nCorner of Hatched rectangle: ")
    p2 (getcorner p1 "\nOpposite corner: ")
  ); setq
  (command "_.-hatch" "_properties" "_solid" "_W" "_no"
    "_non" (list (car p1) (cadr p1)) "_non" (list (car p2) (cadr p1))
    "_non" (list (car p2) (cadr p2)) "_non" (list (car p1) (cadr p2))
    "_close" "" ""
  ); command
  (prin1)
Kent Cooper, AIA
Message 17 of 29
k005
I'll look into this... Thank you.
Message 18 of 29
pendean
Community Legend
Community Legend
HATCHes are rectangular, you always have to account for the other two corners in your PT1-PT2 lisp-wish: this is just a different way to do that.
Message 19 of 29
k005
Awesome .! Thank you for your hard work.
I added this to the code below. it was very nice.
We, technical people, should work with 0 errors or very close to 0 errors... 😉
Message 20 of 29
CADaSchtroumpf
Certainly we could improve the code to memorize the last value of the wall height.
But one feature of autocad, which works for both user input for native commands and for input in lisp codes is that: when prompted to enter a value, you press the up arrow on the keyboard of the directional pad.
This action recalls the last value entered, you only have to validate by entry to validate this value.
It is a sort of history of previously entered values.
