Point1 and Point2 to Hatch
k005
Advisor Advisor
Message 1 of 29
k005
Hello everyone
As I mentioned in the attachment, how can I have a solid scan automatically when I mark pt1 and pt2?
The place where I operate is a closed area...
Thanks.
Replies (28)
Message 21 of 29
k005
Yes, of course. This may be what you mean by remembering. However, since there is no loop, it will be necessary to enter the command again. I want to add both cases to this code. I am also experimenting.
* Of course, it can still be used this way.
Thanks.
Message 22 of 29
CADaSchtroumpf
So here is the version for a loop and memorization (and proposition) of the last value...
Message 23 of 29
k005
In one word, Super! 🤗
Thank you very much. @CADaSchtroumpf
Message 24 of 29
calderg1000
Regards @k005
Try this little code, maybe it will help you.
(defun c:hh3 (/ p1 p2 s)
  (setq p1 (getpoint "\nPick Point 1: ")
        p2 (getpoint p1 "\nPick Point 2: ")
  (command "_rectangle" p1 p2)
  (setq s (entlast))
  (command "_-hatch"
           "s"
           s
           "_P"
           "s"
           "_draworder"
           "l"
           "B"
           "_erase"
           s
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 25 of 29
k005
There was a small bug. This solved it. Thanks @calderg1000
Message 26 of 29
k005
Hello my friend.
Can we revise the code in angled walls?
Message 27 of 29
k005
* I can make a front preparation with the UCS/E option for the angled wall in terms of helping ...
Message 28 of 29
Kent1Cooper
If they're not orthogonal, then picking two points at opposite corners of the intended area would have an infinite number of valid results.  It is going to require something more than two points -- three should be enough, or two plus selection of some edge of the area to establish the angle.  But then it's not very much simpler than just using the native SOLID command [which will have you pick four points].
Kent Cooper, AIA
Message 29 of 29
k005
I think like this; First of all, if we change UCS/E and watch an approach. When I go to the angle of the angled line, a flat floor is formed again ... Here, even if there is no solid hatch. No problem. If we calculate the thickness of the wall and print it. It could be in a separate routine ... C: Ang.
