vlisp editor doesn't open anymore
gert.valk
gert.valk
vlisp editor doesn't open anymore, when it start up i can only see a small icon in my taskbar and in the upper left corner i see this symbol in bleu ( )!2018-02-17 09_01_40-.png
devitg
Seem to be it is open , you shall open the editor window , or try to open any LISP , it will open your edit window.
lando7189
Its probably just off screen.
Hit the 'Alt' key & Space bar together, then hit 'X' -- it should maximize it.  Then grab the title bar and move it.
-didier-
Coucou
search the file vlide.sdk, delete it and everything will come back normal
amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
-didier-
the path on my pc :
C:\Users\Utilisateur\AppData\Roaming\Autodesk\Autodesk AutoCAD Map 3D 2015\R20.0\fra
DA
gert.valk
Dear Lando,
Many thanks this was the solution for my problem.
