Auto Number and add prefix to blocks attributes
I used to have a LISP routine called something like "Autonum."
I no longer have it, but it helped me quite a bit.
I have searched everywhere online to find it again, but have had no luck.
Example:
If I had attribute text that said the following:
NP-131, NP-145, NP-67
And I needed it to read:
NP-1, NP-2, NP-3
With that LISP routine I used to have, I could type in a prefix (in this case it would be NP-) and then select an increment of number to increase (I would set it to 1). I would then select the each attribute text that I wanted to change to that order.
Does anyone know of such a LISP routine??
See screenshot attached
_gile
This is not LISP, but the Increment plugin on the App Store does what you need and some more.
If you absolutely want a LISP solution, you can try Increment.lsp (INCSUF or INCSEL commands) but prompts and comments are in French.
It also seems to me Lee Mac have written a nice routine (search here).
Gilles Chanteau
GileCAD
GitHub
The routine that @_gile expos is:
