Autolisp layer group
larsTB09
Message 1 of 11
larsTB09
Hello all,
I need some help to create a autolisp command that changes the color of the layers in a certain layer group?
Thanks by advance?
Replies (10)
Message 2 of 11
ВeekeeCZ
Do you mean a Layer Filter Group, or just list of layers...
The most simple way is:
(defun c:LayersToRed ()
  (command "_.layer" "_Color" 1 "Layer1,Layer2" "")
  (princ)
List of layers delimited by a comma. Or a wildcard can be used too: Layer*
Message 3 of 11
(defun crl (layname laycol)
  (entmake (list
	     (cons 0 "layer")
	     (cons 100 "AcDbSymbolTableRecord")
	     (cons 100 "AcDbLayerTableRecord")
	     (cons 2 layname)
	     (cons 70 0)
	     (cons 62 laycol)
	     (cons 6 "Continuous")
(defun c:my_layers ()
      (setq lay_cba (list
		       (list "Lay1" 1)
		       (list "Lay2" 2)
		       (list "Lay3" 3)
		       (list "Lay5" 4)
		       (list "Lay5" 5)
		       (list "Lay6" 6)
		       (list "Lay7" 7)
      (foreach n lay_cba
	(crl (car n) (cadr n))
  (princ)
I use this.
Message 4 of 11
Kent1Cooper
@larsTB09 wrote:
....I need some help to create a autolisp command that changes the color of the layers in a certain layer group? ....
If a "layer group" is a collection of Layers with related names, you can handle them collectively, with wildcards.  For example, if you want to make all Layers whose names start with ABC [say, ABC1, ABC2, ABC3, ABCwhatever, ABCetc], you can do:
(command "_.layer" "_color" yourColor "ABC*" "")
Kent Cooper, AIA
Message 5 of 11
larsTB09
Is it possible to change all layers to color 253 extept for the one i asked in the getSting?
(defun c:TEST ()
(setq EXTEPT(getstring  "\nyour prompt:"))
  (command "_.layer" "_Color" 253 EXTEPT)
  (princ)
Message 6 of 11
_gile
Here's a way using tblnext to get all layers and entmod change the layer color.
The routine also uses wcmatch to check which layer(s) must not be changed so that you can enter more than one layer names separated by commas and/or use wild-card patterns.
(defun c:TEST (/ except layer name)
  (setq except (strcase (getstring "\nyour prompt: ")))
;; iterate through all layers (while (setq layer (tblnext "layer" (not layer))) (setq name (cdr (assoc 2 layer)))
;; check if the layer name matches with the exception (if (not (wcmatch (strcase (cdr (assoc 2 layer))) extept))
;; change the layer color (progn (setq layer (entget (tblobjname "layer" name))) (entmod (subst '(62 . 253) (assoc 62 layer) layer)) ) ) ) (princ) )
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
ВeekeeCZ
Well, if it is the only ONE exception, then its easy, use a tilde (~) prefix.
(defun c:TEST ( / except)
  (setq except (getstring T "\nChange all layers to gray, but <all>: "))
  (command "_.layer" "_Color" 253 (strcat "~" except) "")
  (princ)
You may add T to the (getstring T "Prompt") command to allow to type the layer name with spaces.
Edit: You can also use _giles routine if you need the exception for more layers -- just fix the misspell:
(if (not (wcmatch (strcase (cdr (assoc 2 layer))) except))
Message 8 of 11
larsTB09
Hi great! thanks but i have only one more problem. the layer's with the hatches doesn't change?
Message 9 of 11
_gile
Is it the layer color which doesn't change or the Hatch color which is different from ByLayer?
Gilles Chanteau
GileCAD
GitHub
Message 10 of 11
larsTB09
No it’s by later but it happens with all the hatches
Nevermind it works 🙂
Message 11 of 11
_gile
Nice.
Gilles Chanteau
GileCAD
GitHub
