vlax-curve-getdistatpoint
john.uhden
Mentor Mentor
john.uhden
Is there any reason this function would return 0 if the point provided is not at the start of an LWPolyline?
Maybe it's because I'm using 2002?
John F. Uhden
CodeDing
@john.uhden ,
No, there should be no reason. Are you encountering a scenario where it is? Provide insight if so
Kent1Cooper
It does that if you give it the start/end of a closed one, even if you request it for the end point:
(vlax-curve-getDistAtPoint pline (vlax-curve-getEndPoint pline))
returns zero [also for other closed shapes -- Circle, Ellipse, Spline].  But the Parameter approach to the same question does give the length of the Polyline [or other].
If you're not talking about the start/end point, is it just close enough to the start for display rounding to show zero?  Post a little drawing indicating where the Point in question is along the Polyline.
Kent Cooper, AIA
john.uhden
@CodeDing & @Kent1Cooper ,
It was all my fault.
Before you ask for distatpoint, you have to get the closestpointto...
(defun @getdistatpoint (e p)
  (vlax-curve-getdistatpoint e
    (vlax-curve-getclosestpointto e p)
The zero was my own mistake (embarrassing).
John F. Uhden
