Visual LISP, AutoLISP and General Customization
vla-put-canonicalmedianame
6 REPLIES 6
matthew_taylor
2188 Views, 6 Replies
Hello everybody!
I HAD my VLISP plotting working brilliantly...
Now that we have new plotters, I'm having a little trouble with setting the canonicalmedianame!
I use the two utilities below (cribbed from this site; sorry I seem to have lost the credits) to get the media size. That all works fine, but I'm having trouble setting the papersize to the layout object.
I'm plotting to a PC3 file going to a system printer (Oce TDS450).
This line produces the error:
(vl-catch-all-error-p (vl-catch-all-apply
'vla-put-canonicalmedianame (list TABOBJ PLOTTERPAPERSIZE)))
I have tried the medianame as it comes, UPPER and lower cases, replacing the spaces with underscores (_) to no avail. Does anybody have a clue what I need to do to set the medianame correctly?
This is the media name: "Oce A1 594x841 mm"
Any help would be gratefully received!
Matt
(setq LPAPERSIZE "A1")
(setq PLOTTERPAPERSIZE (WSPCS:GETMEDIASIZE:GLMN LPAPERSIZE))
;;;(WSPCS:GLMN:LIST)
(defun WSPCS:GLMN:LIST (/ GLMN:LIST ACTLAYOUT PLNM)
;; getting cannonical media names
(setq ACTLAYOUT (vla-get-activelayout (WSPCS:ACTIVE-DOCUMENT)))
(vla-refreshplotdeviceinfo ACTLAYOUT)
(setq PLNM (vla-getcanonicalmedianames ACTLAYOUT))
;; list of canonnical media names
(princ (vla-get-configname ACTLAYOUT))
(setq GLMN:LIST '())
(foreach ITM (vlax-safearray->list (vlax-variant-value PLNM))
(setq GLMN:LIST (cons (vla-getlocalemedianame ACTLAYOUT ITM) GLMN:LIST)))
(reverse GLMN:LIST))
;;( WSPCS:GETMEDIASIZE:GLMN "A1")
(defun WSPCS:GETMEDIASIZE:GLMN (PAPERSIZE / MEDIALIST TMEDIASIZE CNTR MEDIASIZE CNTR2)
(setq MEDIALIST (WSPCS:GLMN:LIST)
CNTR 0
CNTR2 CNTR)
(while (< CNTR (length MEDIALIST))
(setq TMEDIASIZE (nth CNTR MEDIALIST))
(if (or (wcmatch (strcase TMEDIASIZE) (strcat "*" "OVERSIZE" "*" PAPERSIZE "*"))
(wcmatch (strcase TMEDIASIZE) (strcat "*" PAPERSIZE "*" "OVERSIZE" "*"))
(wcmatch (strcase TMEDIASIZE) (strcat "*" "EXPAND" "*" PAPERSIZE "*"))
(wcmatch (strcase TMEDIASIZE) (strcat "*" PAPERSIZE "*" "EXPAND" "*")))
(setq MEDIASIZE TMEDIASIZE
(setq CNTR (1+ CNTR))))
(if (not MEDIASIZE)
(while (< CNTR2 (length MEDIALIST))
(setq TMEDIASIZE (nth CNTR2 MEDIALIST))
(if (or (wcmatch (strcase TMEDIASIZE) (strcat "*" PAPERSIZE "*"))
(wcmatch (strcase TMEDIASIZE) (strcat "*" PAPERSIZE "*")))
(setq CNTR2 (1+ CNTR2)))))
MEDIASIZE) Message was edited by: Matt Taylor
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
6 REPLIES 6
bnarum1
in reply to: matthew_taylor
set desired paper and then run this..
(vla-get-CanonicalMediaName (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object))))
this will tell you the variable you need to set. It maybe something different than the plot dialog is showing.
bnarum,
A good study of reverse engineering!
It worked great, thanks for your help.
Matt
Cheers,
-Matt
bnarum1
your welcome
these are words I live by...
"We can't solve problems by using the same kind of thinking we used when we created them." --Albert Einstein
Love it!
Cheers,
-Matt
replacing spaces w/ underscores might not be accurate, u can create a list
of the
locale meda names and their corresponding canonical mdia names
something like this
(setq aobj (vlax-get-Acad-object)
adoc (vla-get-ActiveDocument aobj)
alob (vla-Get-ActiveLayout adoc))
(vla-put-Configname alob "Oce TDS450.pc3")
(vla-RefreshPlotDeviceInfo alob)
(setq tls nil plnm (vla-GetCanonicalMediaNames alob)) ;; list of
(foreach itm (vlax-safearray->list (vlax-variant-value plnm))
(setq tls (cons (cons (vla-GetLocaleMediaName alob itm) itm) tls)) )
;; tls is the list of all the sheet names with their corresponding canonical
name
HTH
wrote in message news:5387341@discussion.autodesk.com...
Hello everybody!
canonicalmedianame!
Matt
GLMN:LIST)))
MEDIASIZE CNTR2)
CNTR 0
CNTR2 CNTR)
PAPERSIZE "*"))
(if (not MEDIASIZE)
MEDIASIZE)
Stylish solution Mark, thank you!
I'll incorporate this into my function.
Cheers for your time,
Matt
Cheers,
-Matt
Forma Design Contest
AutoCAD Beta
