vl-cmdf
vl-cmdf
scott_bolton
Message 1 of 17
vl-cmdf
scott_bolton
When I load a (vl-cmdf...) line of code from the VLIDE the command works OK but AutoCAD is left hanging. No amount of [ESC]'ing brings it back. If I run the entire routine from the VLIDE or AutoCAD all is fine, it's just if I "Load selection". Any idea why?
Example: (vl-cmdf "_extrude" SMK_temp_ent "" SMK_height)
Replies (16)
Message 2 of 17
paullimapa
Any difference if you use command or command-s
Paul Li
IT Specialist
@The Office
Message 3 of 17
scott_bolton
Nope.
Message 4 of 17
paullimapa
how about using this code:
(vla-Sendcommand(vla-Get-ActiveDocument(vlax-Get-Acad-Object)) "_extrude\n!SMK_temp_ent\n\n!SMK_height\r"))
Paul Li
IT Specialist
@The Office
Message 5 of 17
Sea-Haven
Works for me I used copy and paste the 1 line to command line, note I did set the values 1st. That could be your problem trying to run from vlide.
: circle Select center of circle rad etc
(setq smk_height 100)
100
(setq smk_temp_ent (car (entsel))) ; pick circle
Select entity: <Entity name: 6343fcd0>
T
Message 6 of 17
paullimapa
If you’re running AutoCAD 2022 and above, you should consider switching from using vlide to VB Code which is what Autodesk now recommends
https://help.autodesk.com/view/ACD/2022/ENU/index.html?guid=GUID-7BE00235-5D40-4789-9E34-D57685E8387...
Paul Li
IT Specialist
@The Office
Message 7 of 17
scott_bolton
The command runs correctly, it's just the behaviour of AutoCAD afterwards - it hangs.
Message 8 of 17
scott_bolton
They've been suggesting this for years, but given they've just introduced lisp for 2024 LT I'm not worried.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/whats-your-thoughts-on-autolisp-in-a...
Message 9 of 17
ВeekeeCZ
Would you post the actual code? And possibly sample file.
Message 10 of 17
scott_bolton
(setq SMK_ent (car (entsel)))
(setq SMK_height 0.050)
(vl-cmdf "_extrude" SMK_ent "" SMK_height)
No file necessary - you just need a small rectangle. Just paste the code into the Visual LISP Console. The hanging behaviour is exhibited in all files when you switch back to AutoCAD.
Message 11 of 17
ВeekeeCZ
Well, I can see that. If I replace vl-cmdf with command, it seems ok. I can only guess why is that.
But... why is that the issue? If it works fine from VLIDE, also fine if running from ACAD command-line... it never occurs to me to try it from the console. But I just never use the console for acad commands.
Message 12 of 17
scott_bolton
Good! I'm glad it's not just me.
The reason why it's a problem is that I load the particular code that I'm working on in a lsp file to check it.
Message 13 of 17
ВeekeeCZ
Just a question, why do you prefer vl-cmdf over command.
Message 14 of 17
scott_bolton
For the reason it was introduced:
Message 15 of 17
ВeekeeCZ
Ok, so you know how it works.
Sorry, I can't figure out any logical reason why it should be a problem for vl-cmdf, unlike command (at least in my case).
Message 16 of 17
paullimapa
what does this have to do with LT since VLIDE only works in AutoCAD
Paul Li
IT Specialist
@The Office
Message 17 of 17
komondormrex
it is not a problem with vl-cmdf at all. it is problem with VLIDE software and since i've experienced similar situation more than once with different lisp statement or lisp statements in various scenarios i would recommend  do not make such experiments with VLIDE while you are on something important to not loosing it.
