change width of mtext, mtext in leader, dimension and block attributes
mruPRQUJ
mruPRQUJ
Hi there,
Could you please provide one lisp to perform the below task?
To change width of mtext, mtext in leader, dimension and block attributes, thank you very much in advance. 🙂
Kent1Cooper
Illustrate what you mean [before and after in each case].  Do you mean the width factor of text content within these things?  Mtext has another kind of width, so we need to know which "width" you want.  Can you just change the width factor in the definition of the Style used?
Kent Cooper, AIA
mruPRQUJ
yes, change width factor. Sorry, I did not say it clearly. I want to change width factor of mtext in the leader, selected by contents, for example, "DETAIL 1". thanks a lot!
Kent1Cooper
@mruPRQUJ wrote:
.... change width factor of mtext in the leader, selected by contents, .....
So does that mean there would be other Mtext [etc.] using the same text Style that you would not want changed?  Meaning you can't do it by changing the width factor in the Style definition?
Kent Cooper, AIA
mruPRQUJ
yes, correct. 🙂
