Problem in drawTwoRectangles
jaimuthu
Message 1 of 16
jaimuthu
(defun c:drawTwoRectangles ()
  (setq pt1 (getpoint "\nSpecify the first corner of the first rectangle: "))
  (setq pt2 (getcorner pt1 "\nSpecify the opposite corner of the first rectangle: "))
  (setq width1 (distance pt1 pt2))
  (setq width2 0.46)
  (command "_rectang" pt1 (polar pt1 (angle pt1 pt2) width1) width1)
  (command "_rectang" pt1 (polar pt1 (angle pt1 pt2) width2) (+ width2 width1))
  (princ)
i pick two points two rectangle will be come but error i attached file in detail
Accepted solutions (3)
Replies (15)
Message 2 of 16
Kent1Cooper
Your RECTANG commands are giving three points, but should give only two.  Can you re-post the drawing with an indication of what locations would be pt1 and pt2?  If they're really opposite corners, then the length of the rectangle 1 will not be the distance between them -- that distance would be the diagonal, and greater than the rectangle's length.  Or should your "opposite corner" in the prompt really be "other end of the long edge"?
Kent Cooper, AIA
Message 3 of 16
jaimuthu
i want only pick two points p1 and p2
Message 4 of 16
ВeekeeCZ
Ok, try this.
(defun c:Tworecs ( / w+ p1 p2 ll ur )
  (if (and (setq w+ 0.46)
	   (setq p1 (getpoint "\nSpecify First corner: "))
	   (setq p2 (getcorner p1 "\nSpecify other corner: "))
	   (setq ll (mapcar 'min p1 p2))
	   (setq ur (mapcar 'max p1 p2))
    (command "_.rectang" "_non" ll "_non" ur
	     "_.rectang" "_non" (mapcar '+ ll (list (* w+ -0.5) (- (cadr ur) (cadr ll)))) "_non" (mapcar '+ ur (list (* w+ 0.5) w+))))
  (princ)
This is what mapcar does, if you're interested.
(mapcar '+ '(x1  y1) '(x2  y2)) => '(x1+x2  y1+y2)
Message 5 of 16
komondormrex
like that?
  (command "_rectang" "_non" pt1 "_non" pt2)
  (command "_rectang" "_non" (list (- (min (car pt1) (car pt2)) 0.23) (max (cadr pt1) (cadr pt2)))
	              "_non"(list (+ (max (car pt1) (car pt2)) 0.23) (+ 0.46 (max (cadr pt1) (cadr pt2))))
  (princ)
Message 6 of 16
jaimuthu
Work perfect thanks but i want also pick vertical wall side this code work is horizontal wall now i attached file for your reference
Message 7 of 16
jaimuthu
Message 8 of 16
komondormrex
horizontal and vertical
  (if (> (distance pt1 (list (car pt2) (cadr pt1))) (distance pt1 (list (car pt1) (cadr pt2))))
		              "_non" (list (+ (max (car pt1) (car pt2)) 0.23) (+ 0.46 (max (cadr pt1) (cadr pt2))))
    	  (command "_rectang" "_non" (list (max (car pt1) (car pt2)) (- (min (cadr pt1) (cadr pt2)) 0.23))
		              "_non" (list (+ (max (car pt1) (car pt2)) 0.46) (+ 0.23 (max (cadr pt1) (cadr pt2))))
  (princ)
Message 9 of 16
jaimuthu
its work good  thanks
Message 10 of 16
calderg1000
Regards @jaimuthu
Try this code...
(defun c:Mkr (/ p1 p2 p1x p2x)
  (setq p1  (getpoint "\nSpecify the first corner of the first rectangle: ")
        p2  (getcorner p1 "\nSpecify the opposite corner of the first rectangle: ")
        p1x (mapcar '+ (mapcar '(lambda (x y) (/ (+ x y) 2.)) p1 p2) (list (- (+ (* (abs (- (car p1) (car p2))) 0.5) 0.23)) (* (abs (- (cadr p1) (cadr p2))) 0.5) 0.))
        p2x (mapcar '- (mapcar '(lambda (x) (* x 2)) (polar (mapcar '(lambda (x y) (/ (+ x y) 2.)) p1 p2) (* pi 0.5) (+ (* (abs (- (cadr p1) (cadr p2))) 0.5) 0.23))) p1x))
  (command "_rectang" "_non" p1 "_non" p2 "_rectang" p1x p2x
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 11 of 16
jaimuthu
Thanks its work one side of wall i want four side of wall i attach file in detail
Message 12 of 16
jaimuthu
Your code work its fine but it work two side of the wall i want four side of wall i attach the file in detail what i want
Message 13 of 16
komondormrex
hi,
check the code below. second rectangle is drawn towards direction of minor side of first rectangle.
(defun c:drawTwoRectangles (/ pt1 pt2 pt3 pt4 delta_x_y)
  (setq delta_x_y (mapcar '- pt2 pt1))
  (if (apply '> (mapcar '+ '(0 0) (mapcar 'abs delta_x_y)))
	  (setq pt3 (list (+ (max (car pt1) (car pt2)) 0.23) (cadr pt2))
	        pt4 (list (- (min (car pt1) (car pt2)) 0.23)
			  (+ (cadr pt3) (* (/ (cadr delta_x_y) (abs (cadr delta_x_y))) 0.46))
    	  (setq pt3 (list (car pt2) (+ (cadr pt2) (* (/ (cadr delta_x_y) (abs (cadr delta_x_y))) 0.23)))
	        pt4 (list (+ (car pt3) (* (/ (car delta_x_y) (abs (car delta_x_y))) 0.46))
			  (- (cadr pt1) (* (/ (cadr delta_x_y) (abs (cadr delta_x_y))) 0.23))
  (command "_rectang" "_non" pt3 "_non" pt4)
  (princ)
Message 14 of 16
jaimuthu
thanks this is i want thanks for your reply
Message 15 of 16
calderg1000
Regards @jaimuthu
Try this code, maybe it helps some...
;;;___
(defun c:Mkrs (/ p1 p2 l h pm1 pm2 p1x p2x ss p)
  (princ "\n Top Wall...")
        l   (abs (- (car p1) (car p2)))
        h   (abs (- (cadr p1) (cadr p2)))
        pm1 (mapcar '(lambda (x y) (/ (+ x y) 2.)) p1 p2)
        pm2 (polar pm1 (* pi 0.5) (+ (* h 0.5) 0.23))
        p1x (mapcar '+ pm1 (list (- (+ (* l 0.5) 0.23)) (* h 0.5) 0.))
        p2x (mapcar '- (mapcar '(lambda (x) (* x 2)) pm2) p1x)
  (setq ss (ssadd))
  (command "_rectang" p1 p2)
  (ssadd (entlast) ss)
  (command "_rectang" p1x p2x)
  (princ "\n Botton Wall...")
  (command "_mirror" ss "" (setq p (getpoint "\nPick point in the middle of the right side wall...")) (getpoint p) "")
  (princ "\n Rigth Wall...")
  (command "_mirror" ss "" (setq p (getpoint "\nPPick a point at the top corner of the right side wall...")) (getpoint p) "")
  (princ "\n Left Wall...")
  (command "_mirror" ss "" (setq p (getpoint "\nPick a point at the top corner of the Left side wall...")) (getpoint p) "")
  (princ)
Carlos Calderon G
Message 16 of 16
pbejse
is there a time that the rectangle is at an angle other that 0 and 90?
