Visually See if SNAP is ON via color Swatch?
johnw
Message 1 of 60
johnw
We use SNAP when we draw and as a trainer I would like to easily see if someone has SNAP ON or OFF with a color swatch displayed on the ribbon panel. Is there a way to display a green swatch that is large enough to see from a distance if SNAP is ON and it turn RED if SNAP is OFF? Some folks use the classic toolbar menu as well so the swatch for that would have to be located at the bottom left of the menu in the startup. If someone could show me how to show this color switch in a Ribbon panel setting and as lower left corner of classic window setting that would be fantastic.
Much thanks,
John W.
Replies (59)
Message 2 of 60
Isn't the status tabs at the bottom of thr screen (ORTHO, OSNAP, SNAP, etc.) work for you? The tabs change between dark and light indicating status of OFF and ON
Message 3 of 60
johnw
They don't work from a distance. That's why I requested this.
Message 4 of 60
johnw
Message 5 of 60
ВeekeeCZ
Message 6 of 60
scot-65
(setvar "MODEMACRO" "$(if,$(getvar,snapmode), Snap is ON, Snap is OFF)")
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 7 of 60
johnw
Any way to display a color green if it's on and color red if it's off?
Message 8 of 60
alexKoshman
Why not to change the color OF THE CROSSHAIR!?
Message 9 of 60
johnw
Sounds like a great idea! I have a routine that someone wrote that changes my crosshairs to RED when I'm in paperspace and WHITE when in model space (see attached lisp routine - i had to change extension to .txt for attachment to load). How would I add changing the color to PURPLE if SNAP IS OFF in Either paper or model space???
Message 10 of 60
alexKoshman
You have to fully rewrite this example program with "VLR-SysVarChanged" Reactor for catching user changes the "SNAPMODE" system variable and then change the "ModelCrosshairColor" or " "LaypoutCrosshairColor" Property for Model or Model depending on your current Space!
Message 11 of 60
johnw
Sorry, I don't have a clue on how to do this.
Message 12 of 60
alexKoshman
Sorry! But I have no time to write it now!..
Maybe on weekend?..
Message 13 of 60
martin_leiter
an Example... http://ww3.cad.de/foren/ubb/Forum145/HTML/004108.shtml
Best Regards Martin
Message 14 of 60
alexKoshman
You mean that of cause:
(vla-put-ModelCrosshaircolor (vla-get-display (vla-get-preferences (vlax-get-acad-object)))
  (cdr (assoc 420 (acad_truecolordlg (cons 420 16777215))))
Because we mustn't use "setvar" (see there below) in Reactors for variables changing...
Message 15 of 60
johnw
Do I insert these lines of code inside the file I attached earlier or insert it into the acad.lsp file? Not sure...
Message 16 of 60
alexKoshman
They ARE in the code already!
I told this to martin.leiter...
Message 17 of 60
johnw
I'm sorry I don't understand what you mean. If you added this code to my original attachment can you attach the revised code so I can download it. Or if I need to do something on my end please let me know.
Thanks.
Message 18 of 60
scot-65
Attached file is code for the reactor part.
I was not sure how to handle the "answer" in a timely manner.
However, the attached file reactor does work with limited testing. Remove the ".TXT" extension.
I am also displaying the code here with revisions:
;; System Variable Changed Exercise
(vl-load-com)
(vlr-sysvar-reactor nil '((:vlr-sysVarChanged . Sys_Var_Chg_SNMODE)))
(defun Sys_Var_Chg_SNMODE (obj lst / )
 (if (and (= (car lst) "SNAPMODE") (cdr lst))
  (if (= (getvar "SNAPMODE") 0)
   ;change crosshair color to RED here.
;change crosshair color to GREEN here. );if );if (princ) );end Sys_Var_Chg_SNMODE
Good Luck.
Scot-65
Message 19 of 60
johnw
Thanks Scott, I got this working in modelspace! Thank you.
Thank all of you for your comments and help!
Message 20 of 60
scot-65
Just an additional thought...
The crosshair color is recorded into the registry when editor is closed.
By opening another file that has the opposite setting of SNAPMODE
the color would be wrong.
To fix this, add code inside S::STARTUP (or equal):
(vl-load-com)
);if
Scot-65
