Arc report
Arc report
sean.keohane
Message 1 of 9
Arc report
sean.keohane
I have pieced together this lisp which is intended to report 4 dimensions.
E = radius
A=arc length
B=Chord
C=Rise.
The E, A, and B are reporting for me but only when I exclude the C equations which I obviously haven't got right.
This is intended strictly for arc's to double check schedules of reinforcement shape code 67. (British standard code for a radius bar).
It reports to screen but I hoped I could get it to insert a text near the selected arc but I got bogged down with the C dim issue.
Can someone more knowledgeable than I,take a look and set me straight.
Much appreciated
Regards
Sean
Replies (8)
Message 2 of 9
Kent1Cooper
Very quick perusal -- perhaps make this change?
  (setq p4 (vlax-curve-getpointatdist x (* A 0.5))) ; midpoint of arc
Kent Cooper, AIA
Message 3 of 9
doni49
Kent is very good at this so there's a good chance he's solved it.  But in case he hasn't, I'll ask this:  can you give us a layman's version of how C is supposed to be calculated?  Write it as though you're a teacher and you're showing the formula to your students for the first time.
Just C = ................. (the algebraic formula).
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 4 of 9
phanaem
The problem in C formula is that A is a string, and cannot be used.
Maybe this:
(defun c:test (/ ARC A B C E)
  (vl-load-com)
  (cond
    (*activeDoc*)
    ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))
  (if (setq ARC (ssget ":S:E" '((0 . "ARC"))))
    (progn
      (vlax-for x (setq ARC (vla-get-activeselectionset *activeDoc*))
        (setq E (vla-get-radius x))
        (setq A (vla-get-arclength x))
        (setq B (distance
                  (vlax-curve-getstartpoint x)
                  (vlax-curve-getendpoint x)
        (setq C (* E (- 1 (cos (/ A E 2.0)))))
        (textpage)
        (prompt "\nShape code 67 dimensions: ")
        (prompt "\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ")
        (prompt (strcat "\n\t\tDim E >> " (rtos E 2 2) " mm"))
        (prompt (strcat "\n\t\tDim A >> " (rtos A 2 2) " mm"))
        (prompt (strcat "\n\t\tDim B >> " (rtos B 2 2) " mm"))
        (prompt (strcat "\n\t\tDim C >> " (rtos C 2 2) " mm"))
        (terpri)
      (vla-delete arc)
  (princ)
Message 5 of 9
sean.keohane
Hi Kent,
I tried your suggestion but no joy. I think I'm doing something else wrong, as well. I appreciate your input.
Regards
Sean
Message 6 of 9
sean.keohane
Hi Doni,
I'm not a mathematician but what I'm attempting to achieve with the code at Setq C is find the distance between the midpoint of the chord to the midpoint of the arc. I think this is called the sagitta in maths speak. The equation s = r - \sqrt(r^2-l^2), where s=sagitta, r=radius of arc and l=chord/2.
I hope this is correct.
Thanks for your reply,
Regards
Sean
Message 7 of 9
sean.keohane
Hi Phanaem,
I tried your code and it works. Thank you for helping me out. You made it less complicated which, for me, is always a good thing! I'm going to research your code to understand how it works now.
Regards
Sean
Message 8 of 9
Kent1Cooper
Further possible streamlinings....
If it's letting you select only one Arc, it hardly seems worth using a function such as (vlax-for) that's made for stepping through multiple objects, and the whole active-selection-set and active-document stuff associated with that.  And you can combine things so that it involves only one (setq) function after the initial Arc selection, and only one (prompt) function.  [I also prefer to pull (vl-load-com) outside of command definitions, because you don't need to run it every time you run the command, but only once, when you load it.]  I think this is equivalent:
(defun c:test2 (/ arc A B C E)
  (if (setq arc (ssget ":S:E" '((0 . "ARC"))))
    (progn
      (setq
        arc (vlax-ename->vla-object (ssname arc 0))
        E (vla-get-radius arc)
        A (vla-get-arclength arc)
        B (distance (vlax-curve-getstartpoint arc) (vlax-curve-getendpoint arc))
      ); setq
      (textpage)
      (prompt
        (strcat
        ); strcat
      ); prompt
      (terpri)
      (vla-delete arc); [do you really want to do this?]
    ); progn
  ); if
  (princ)
); defun
(vl-load-com)
Kent Cooper, AIA
Message 9 of 9
sean.keohane
Hi Kent,
I was really making things difficult, wasn't I. Thanks for explaination, I always have an uphill battle getting my head around lisp. Alot of trial and error before I call in the troops. Although, the odd time I get something working without help, gives me a sense of satisfaction.
I appreciate your time,
Regards
Sean
